The Texas Buck driver series, Q8 / Skyray King 2S/4S buck driver RELEASED!
Great. The only things I have left for this model are reviewing the input caps again and Coff charging. My input cap loss numbers were wrong (just the percentage form, but that's what I was looking at) but voltage swing is now a bit of an issue, especially at 4:1 and a little at 2:1. With more wiggle room on ESR now, I'll want to review again if I can find bigger caps that are suitable. Ti has a document about this and they use 82uF for a 10A supply.
For Coff, it's a matter that setting it up for a good frequency at one voltage will probably make considerably unoptimal frequencies at other output configurations, but at worst it means you need to select new RC for different applications.
Both issues will work the way they are, but may be significantly improvable too. But I won't wrap up my notes on them for a few days at least.
Thats fine, I will start trying to find the large components from Arrow and we can work out the values for the caps and resistors later, those are easy.
Well yes and no.. values above 1 uf at moderate voltage have size constraints. I haven't looked beyond ceramic. The coff thing would also be a rewire, I don't expect you to be convinced on that until I convince you, and it can be a beta revision (this being alpha) if it ever happens. Again this all will work as is, and can be tested as is if it's go time.
Remind me what the coff thing was, just too busy lately to put my head into this like I should. You have been a big help, there is no way I would have had time this year to research parts selection enough to really get this project going. Still not sure how you find some of these things.
Heck I was just looking for a simple compact op-amp for a possible linear driver and was coming up with almost nothing.
It is not a major rush or anything, I am just making an order from arrow anyways and with the discount code I have it should make it reasonable to order a set of parts to give this a try. So I figured I would grab it while I can. Not worth making an order just for these parts if I have to pay shipping.
Same reason I was looking for an op-amp.
Well 95% of it has been useless lol. It's like the monkey with a keyboard thing, but I like to be satisfied that the options have been explored.
Coff is the offtime clock (buck cycle off-time, not the traditional OTC). Frequency depends on that and duty cycle (on time) which is Vout/Vin so it depends on Vo no matter what you do. But they also charge it off Vo which modifies that Vo dependence. I'm not sure that modification is useful for our purpose. Charging it off Vin or maybe now even off the more stable ldo, might give a more all-purpose setup for us. But I'll have to generate all the numbers, mostly done, but still, no time is no time.
It hits me that if we really want to nail the Iadj thing, we have have to consider the output resistance of the mcu (both high and low if different). I think it's specced at 5ma output (this might be entirely wrong/bad memory), but I don't know if it's limited to that by 1kohm ish internal resistance or if it just means we shouldn't draw more than that off of it. Using 10k ish output, of course that's a 10% correction on the voltage divider. That's not a design change though, just details of the setup to work out/refine either in tweaking iadj resistors and or rsense. Probably just things that will get fiddled with in field testing.
I guess this could be an argument for not using the second resistor (but we still don't have to use it).
Edit looks like output and input impedance are about 20 to 40ohms depening on Vcc, so no problem.
Ok, found the big components from arrow, they are actually a fair amount cheaper here as well:
Inductor: https://www.arrow.com/en/products/ihlp6767gzer150m11/vishay
Diode: https://www.arrow.com/en/products/stps30l30djf-tr/stmicroelectronics
Mofet: https://www.arrow.com/en/products/si7157dp-t1-ge3/vishay
Buck IC: https://www.arrow.com/en/products/lm3409mynopb/texas-instruments
First a minor thing: I have actually polished off some thoughts on Iadj, but no time to write it up. Basically the diode bias current is going to cause a voltage offset at high resistances, preventing to reach zero, but you get ripple using low resistances. None of it is terrible, but may we may need to live with some compromise between the two. It's mostly unrelated to the two resistor issue.
Now the bad news. For the first time I looked closer at the mosfet. That mosfet has 625nC of gate charge at 10V. I hadn't really noticed that before. That seemed a bit giant to me, and well, it kind of is. That's 63nf of gate capacitance!
Both the potential and charging energy is lost every cycle so just P=CV^2*f (no 1/2). Switching voltage is 6V, fixed in the IC (Vin-Vcc).
so 63E-9*6^2*1E6 = 2.268 W! (I hope I made a mistake here, but I don't think so)
That doesn't sound sooo aweful, but that's happening all the time. So at 2W power output, you've got 2.3W of switching loss. No fancy coff correction helps this. Coff, and frequency only are impacted by voltages (and are under our control anyway). This may finally be the reason PWM from full power doesn't work out so bad after all!
There are other mosfet losses that I've barely thought about. It seems very complicated actually and I likely won't ever find time or energy to deal with it all, but anyway this gives us a measure of at least part of it, and some relevant spec to improve.
I'll present the case about Coff when I get time to present it, but it's a triviality compared to this I think. Although the two will be very linked. This may drive the need to care more about how set the frequency.
Time to look carefully at what fets are available again. I read a doc, maybe Ti, exactly warning against overspecced large, low rdson fets, for this reason. We might need to look for something a little less beefy. However, I still probably don't much free time for a bit.
For comparison quickly the SIR404dp nfet has only 97 nC of gate charge. nfets are said to be better. Starting to see why. I might be giving that high side nfet driver another look, but not before looking for more suitable pfets.
Please let us know when these boards are available.
The PCB is basically done but it is useless without the parts list to fill it so waiting till we get that knocked out before releasing the PCB. I don’t want people spending money on something that doesn’t work, or at least have the possibility of working.
Hope we find out soon. Like!!
A little quick searching does look like there are better fet alternatives to solve this, need to compromise a little on rdson probably. Might require a minor footprint/pad change. (maybe soic-8, so pretty close I think) No time to pin it down right now.
And yeah, like TA says, drawing a basic board that will get electricity in one side and out the other, well probably isn't easy at all actually, but the details of how well all the parts really work together are MUCH more complicated in a buck than a DD or linear driver. We probably wont predict all the issues, which is a reason at some point to get on with it to see, but when it doesn't work you want to have some handle on as much as possible too so it's not just time to shrug. Some of these things are easily predictable (probably even some of the ones we'll miss), and staring at a board that doesn't make light will only give so much insight into it. Although it's been a little quiet here, I have been making progress on a few things slowly. We just never really looked into the FET in any significant detail at all until now. Not a big deal, but I have about 70 rows of calculations or inputs, none of which are a big deal. Just takes time to get around to thinking about them all. It will get there, probably.
No problem, I have been swamped myself so I understand.
A couple of Mosfets:
http://www.digikey.com/short/3bjdqf
http://www.digikey.com/short/3bjd8h
Both are very similar, same footprint to the previous one (better double check the pins)
Both about 20x less gate capacitance and about 10x more Rdson, which works out as a big win I think. (Notice the 74W one quotes gate charge at 4.5V and the 100W one at 10V, so they’re pretty similar once that's corrected). I kind of like the 100W one but the difference is miniscule, so whichever costs you less. Don't know what I was reading. They are pretty similar but in fact the 75W one has lower gate charge and I'd pick it probably. Plus it's cheaper.
There are some other options with better numbers for rdson and gate charge, but either bigger, less standard, or worse thermal performance as far as I found. I think these are a good compromise. I don’t swear the the best possible, but they bring down a 2.2W low power drain to now about 0.2W.
There is an Rdson hit at very high power, 5.3% loss at 20A, regardless of duty cycle. That's 14W in 1:1 (but that's in a 280W output mode, lol). It maybe a little less crazy to see this happening in 4:1 where that's only 3.7W because 20A 4:1 is only 70W total. Either way, it's still a 5.3% loss at 20A though.
At a more reasonable 10A 1:1 output it's 4x less loss (I^2 R) so 3.5W, not so bad, especially since we saved 2W in gate drive (and maybe more in other fet capacitance and speed issues I suspect; these are just lighter on their toes). I definitely think this is a good tradeoff. Unless you only ever run your light on meltdown mode, these fets are better, but the buyer can choose.
I've got new numbers about ready. I want to revisit input cap selection still. I was wrong aout Coff charging. On balance of all the numbers, we should leave it alone. Further improvement can only be done by selecting the RC for the desired output voltage.
We're close.
Those both look good, I agree either should work and just pick one based on cost and availability.
Well I got confused (too many digikey windows, dizziness sets in). They're both quoted at 4.5V, so I'd pick the cheaper 75W one then with lower gate charge: STL30P3LLH6
If there's any competition, it's maybe this:
http://www.digikey.com/short/3bj1h8
STD37P3H6AG
Half the Rdson, but twice as much space.
Those are only sold in 2500 increments, so I am gonna say those are not real practical due to that lol.
Although while it may be able to fit I think that keeping to the powerpak footprint is wiser.
