The product page says "Smartxchoices Pro 2In1 862D+ SMD Soldering Iron Hot Air Rework Station LED Display w/4 Nozzles As Free Gifts (#1)". It looks pretty good. The price is $55.49 (say 45% off).
$99 is too much for me this year. I’m not sure about the pump in the base. I’m sure it is more reliable and robust, but it also makes the cord/tube to the unit thicker. Does that get annoying in your experience?
It looks like the MarkEthan 852D you linked in post #2. Price is the same as posted on weldandsolder.com.($55.59). When you click “add to cart” button there it takes you to Amazon to finish checkout
The cord/air tube is much thicker, but it hasn’t been a problem for me because it’s very flexible . You may, or may not like it. I’d invite you over to check it out if you ever visit Long Island
The 862D+ looks pretty good right now, I like the completely separate controls for air/iron. I just can’t find any specs on the wattage ratings for each side.
I have the Aoyue 937+ with several Hakko T18 tips. It’s like a whole new solder station with the Hakko tips. They work so much better than the tips that came with the station.
The three I bought were half the price of the solder station. A cylindrical point, 2.4mm chisel tip, and a 3.2mm chisel tip. About 8 bucks each, but they sure work good.
Either unit would never do for me. I would never give up my Hakko iron - there's no wiggle room there. One time I accidentally cut through the cord to the iron - replacement cost almost as much as the full up iron - I ordered another Hakko without delay. Felt like a complete novice using my backup - totally useless. The Hakko is that good. Dale says pretty much the same thing about his. Dunno how anyone else mods without one, or something comparable.
I have no problems with my iron, I’m just worried about having space on desk for two boxes and two power cords. That’s why I’m primarily looking at combo units.
For flashlights use i am currently working with Gordak 850, using it for 2 years already, made like 300+ drivers, dedomed zounds emitters, remade lotsa drivers and dismanteled unknown numbers of other el.components- working like a champ- bought it vs….prolly 80 usd
Meanwhile my work Weller Hot Air station failed twice, price difference is above 20x
