Some Beamshot outdoor (Reflector OP) ( OP reflector VS SMO reflector comparison will be done tomorrow night)
Here we go (Please ignore the red-color switch led on the proto; final products are with Blue color switch, Tom E will receive one final light for review next week)
MT07 CW VS Car High-beam (MT07 much brighter and much much longer distance )
A iron tower (400m-500m away)
MT07 light up the tower
Borrowed a Convoy L6 from a friend (He told it’s a 5000K NW)
Left L6 ; Right MT07
MT07 can not call it a pure thrower ; But shot distance is still nice
Beamshots looks good, it seems to be considerably throwier than the L6. HaikeLite can you also do a side by side white wall shot vs the L6 at about 3-5 meters using the OP reflector? Thanks
L6 head at the bezel: 73 mm (75 mm at thickest point, lower down)
L6 reflector: 63.0 mm I.D., 67.5 mm O.D., 48.5 mm depth
As posted in the OP, the MT07 has a 72 mm I.D. and 68 mm depth, so with the extra 9 mm of I.D. width, the MT07 should definitely out throw an L6 with everything else being equal (LED/amps). The extra 20 mm of depth should mean the spill on the MT07 should be narrower by quite a bit, so that should make the spill area brighter, maybe a slight bump in throw, maybe... Good comparative beam shots should make it clear, but we'll have to wait on that - hopefully those great garden beamshots done in Germany will soon include the MT07.
Oh man, I got a little heat at home. Made my wife go home to pickup up the DHL package off the stoop - I was worried..., and got 5 more packages today from USPS. Why must they come all on the same day???
