Ok, that's good news. Well, and maybe it will ramp up to higher voltages too. Maybe I jumped the gun on this assessment and just haven't pushed it hard enough yet.
Ok, that’s good news. Well, and maybe it will ramp up to higher voltages too. Maybe I jumped the gun on this assessment and just haven’t pushed it hard enough yet.
I have not noticed any speed regulation on the fan.
Inside the Dell EPS-470 there is an ATX connector with 12V supply. I’m going to use it to power a 120mm fan.
For those that want to use an ATX or other simular low voltage power supply this same company just released a new buck/boost version of the power supply module.
It outputs 0-32V and the input is 6-40V with a 5A max current.
This really opens the door for more compact and easier to build power supplies if you do not need the higher current and voltage abilities of the DPS5015
It is on sale during the introduction for $28.99 for 3 days, grab it while you can, they always do this when released and the price DOES go up after that.
Great, glad to see an official test. Basically what I figured it would show.
Thanks for this, I’ve looked for a reasonably priced power supply capable of greater than 30V and 10A for close to a year. The sub $100 10A 30V power supply’s are easy to find, and it’ll work for most of the emitters we use here, but I’ve got some projects coming up with COB LED’s and they’re usually have a Vf around 36V. Reasonable 50V power supply’s are also fairly easy to find, but most often have current outputs below 5A, and some even below 3A, which knocks out high-amp/low-Vf LED’s.
Until this it seems it’s been a choice between either high amp, low Vf tests, OR high-Vf, low amp tests.
This seems to fill the void IMO.
Off to read the other threads before I spam you with questions lol.
-Michael
Please post how those projects go. I already have people asking what can be done with COB’s…
FINALLY
my power supply arrived.
Looks to be running at about 97+%?
It is hard to make out from pic.
Not that hard, the magenta curve shows the power loss in it. The maximum is about 10W in all the test I have done, the only significant exception is when I am very close to the current limit.
Here is the Design for the Acrylic case I made in case anyone wants to make one. It is cut out with a laser cutter from standard hardware store .08” acrylic sheet (“plexiglass”). Thicker acrylic would be stronger but costs a lot more and is much harder to find.
Proper acrylic glue will be stronger and look better but hot glue or super glue works just fine as well.
This is an Acrylic case for the DPS and DP line of power supply modules. Any of the Grey box power supply modules here should fit this case : https://rdtech.aliexpress.com/store/923042 Note that the pictures are of aprototype design with a different...
It has been over 3 months since I posted my plans for this ‘build it yourself’ power supply in Post# 73 of this thread. Here it finally is.
Parts Used:
Dell EPS-470 Power Supply, output rating 4mVdc, 9.6amp (Added power switch) $27.
DPS5015 buck controlled power supply $38.
Cooling Fan, 50mm 5v $8.
Connectors for test leads $10.
Misc. scrounged box and hardware $0.
I am quite pleased with it and thanks Texas_Ace for all your assistance.
Looks good! It is always interesting to see peoples different build styles with these.
I am impatiently waiting for my DPS5015 to arrive.
I contacted the seller through AE and asked if he was still doing BLF348 discounts,he said not officially but he would sell me one for $34.
I submitted an eBay “make offer” on one of the EPS-470 power supplies and scored one for $25.
Looking forward to putting it together, mine is also going to be assembled in a “case” made of whatever I have laying around.
Big thanks to all in this thread and elsewhere who dream/scrounge up these great budget ideas for the rest of us to steal.
With the DPS3012 is that a power supply supplied with the control unit, ie I don’t need to buy a separate supply for it?
All of the modules in this thread need a separate power supply for them to work.
I received mine in the mail earlier this week and haven’t had a spare minute to even unbox and test it! It’s driving me crazy!
This weekend…
Is the DPS5015 the highest power unit of this brand?
No DPS over 750W?
It is the highest at this point that I know of.
Ah right. So I’m guessing the external board connected to the DPS3012 is just because the control unit isn’t big enough to contain the beefier components?
Yeah, for that kind of amperage you need way better heat sinking then the self-contained display setup allows.
