[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
++1 :+1:
So it turns out the IM reflector I have mentions is manufactured in China. I got the following response from IM:
"We are willing to do optical ray tracing analysis on other LED options on the 100-1332 reflector.
It is a specular, ultra bright finish, (no facets or flutes).
Attached is a sketch of the dimensions and interface. Please send to me a drawing of the LED/reflector interface you are looking for.
After agreement on the modification requested we can then quote to you min order, price and lead time. Lead time would be 6 weeks and if we can receive the order this week we could deliver before new year.
Yes, reflectors are manufactured by a medical surgery light optical manufacturer in China. We have an NDA in place and orders direct to the manufacturer would not be possible as we own and produce the designs. They use a Swiss M&M machine and can produce parts direct from 3D solid CAD files. Initial parts would be C02 laser cut, before we acquire a die for the production run. "
I told IM that we are early in the Scoping/Designing phase and needed to know what the expected cd/lm would be with an XP-L Hi sized emitter. I realize we will probably got with XHP-35 Hi, but it will be a reference point. I feel further communication with IM should be handled by someone that is experienced in this type of stuff. Maybe the manufacture?. If The Miller feels someone from BLF should work with IM, I will be happy to hand off to that person and introduce them to IM.
They have some promising looking stuff. Someone needs to get with them and see what they can offer.
good info 4Wheelr. I’m glad IM is willing to work with us
Hey guys,
I was being totally creative today, so here’s the idea for a recoil setup, for those who are unfamiliar with the concept.
The concept is simplicity itself, and all of the light from the LED is reflected forward in parallel rays.
Hope it’s helpful and / or inspiring.
I hadn’t yet read this, thanks for the clarification.
Yeah! great, maybe they can shi directly from China to China.
Good to communicate in English with the designers! thanks man!
Oh gosh this looks awesome!
Maybe PM Djozz, he talkedabout recoil thrower as well. Small super focussed recoil with enoruous throw would be an extremely cool project!
A recoil thrower would be interesting indeed, I worry about the cooling ability though. If the LED was mounted in a cross and had a thicker bade plate it is possible but still hard to see all the head being dissipated through tiny supports without blocking the light.
4wheeler that is good news and opens the possibility of using those reflectors if they can be shipped inside china.
If they can run a test on the XP-L hi and let us know what kind of numbers the off-the-shelf units would do we may not even need to custom make one. It would be interesting to hear what kind of improvements they think would be possible with a custom reflector over a pre-made one.
Pre-made would obviously be a lot cheaper, easier and faster.
Put me down for two… Looks interesting.
About the recoil thrower idea and the drawing above: the light intensity of a led decreases at greater angle, therefore, the ‘throw/added surface area of the reflector’ decreases too, meaning that a reflector catching the light up to the full 180 degrees will be increasingly big without adding equivalently to the throw of the set-up. Without having much reference about it, my estimate is that a reflector that catches a cone up to 90 degrees is still sensible.
When time allows, for the fun of it, I will try to make a recoil contraption one of these days to see how well it works, but the thrower of this thread will almost certainly not be a recoil type.
The light intensity decreases at greater angle only because the apparent area of the LED decreases. The luminance would still be the same. So if the reflector catches that high angle light, it should be able to contribute to the throw as expected.
The increase in light collection will not be huge, though; standard reflectors with depth about equal to the diameter collect more than 70% of the light from the LED.
Interested.
About the angle and the recoil concept, i agree the full 180° is not really necessary, but this would probably depend on the LED (dome or no dome, flat or bulbous phosphor) too.
I would probably go for something like 135°, making the reflector some 33% smaller in diameter.
The drawing is ‘for reference only’ :wink:
But a normal reflector cup also uses the wide angled light of the emitter, so i’m not really sure…
Hmmm…
The standard reflector doesn’t reflect the best / brightest bit of the emitted light though…
This is what the ‘problem’ of a normal reflector thrower is, a lot of light is spilled, it’s called “spill”…
A zoomy only uses what would normally be the spill, so with a recoil set up you get both. :slight_smile:
I can’t find proper and affordable parabolic mirrors anywhere though, i have some spherical concave ones, but that just doesn’t work (they’re made for incandescent projector lamps).
In the drawing it is a copper ‘fin’, at least as thick as the thermal slug of the LED’s width.
The weak spot of the heat dissipation is still the LED itself, not the fin.
I think it will be no problem to run any 3535 on 10+ Watts.
3 fins forming a ‘Mercedes star’ would look cool too. :slight_smile:
Ah yes, back on topic, maybe i’ll start a topic on the recoil idea, for this light that deeeep reflector 4wheeler proposes looks very interesting. :+1:
If you haven’t already, have a look at this thread. The throw is just a function of the apparent area of the reflector or lens and the luminance of the LED.
The standard reflector misses the light directly above the LED, but even though this light is the highest intensity, it comprises only about 25% of the total light emitted from the LED. This might seem unintuitive, but it is just a consequence of geometry; the light at more of an angle is less intense, but there is more of it. So an aspheric light might collect the highest intensity light from the LED, but it is only about 25% of the total light.
So I agree that a proper recoil setup could be better in terms of light collection, but it won’t be as much of an improvement as you might expect.
I read that some years ago i think, but i’m not sure what the terms used all mean exactly, so it’s kind of wasted on me…
this (i assume) is 70% of the 180°?
Or is it 70% of the actual light emitted?
This depends also on the relative depth of the reflector.
It will have the tighter beam though and the intensity of a reflector and a zoomy combined.
But enough about it here, i will start a topic about a recoil thrower when i come up with a catchy title. :slight_smile:
(and i made a new drawing, 145° in stead of 180°)
IM supplied an estimated throw with XPL HI. Response is:
"optical simulation of the xplhi LED with the 100-1332 LED. With 1klm, the intensity collimation is around 200 - 235 cd/lm, and 2.5 deg beam."
Not that I want this project to end up as an aspherical thrower, but does recoil flashlight throws better than an aspherical flashlight? Or is it significant?
Does recoil thrower have spill?
I’ve never own any recoil thrower so I am not sure.
A few things I noticed, and of course I’m interested… for Justin and Valerie, the BLF JV Classic. The classic from Thijsco19 looks almost exactly like an Olight SR-90 Intimidator. Might have to make some changes to the fins to get away from any copyright issues. Other than that, the simplicity of form as a carrier of function just works.
I put an XP-L W2 2B in an Convoy C8 yesterday (day before?) and got 2028 lumens at 6.6A. Something to think about.
