Low-cost copper pills, spacers, optics, drop-ins. Custom parts on CNC lathe: 50pcs MOQ.
1597 posts / 0 new
kiriba-ru
kiriba-ru's picture
Last seen: 13 hours 34 min ago
I have forgot about you purchase Texas_Ace. You have set up new record, more than six month between goods receiving and feedback Shocked . Thanks anyway.
Texas_Ace
Texas_Ace's picture
Last seen: 1 hour 1 min ago
LOL, well I only recommend what I have personally tried and in this case I just never got around to building the triples. First the XP-G3 GB took way longer then expected, then I ended up not having enough left over after other projects to build these lights, then I could not decide what LED’s to put in them.
Still got 3 copper adapters left, gonna build another 1 or 2 mixed tint triples to dial in the exact LED’s to make the perfect final tint, then try something else for the last one.
Fesso
Fesso's picture
Last seen: 2 years 7 months ago
I received my parts! Thanks very much and I must complement you on the packaging! Cheers!
“Blessed are the cracked, for they shall let in the light.”
Marx (Groucho)
HorizontalHunter
HorizontalHunter's picture
Last seen: 1 day 4 hours ago
What are you using for your mixed triples?
Bob
Vegetarian: vejiˈte(ə)rēən/noun: old Indian word for lousy hunter.
Mitko
Mitko's picture
Hey m8, i have kinda “wierd” demand LOL
Several month ago i was able to get a russian tweezers from an unknown source( they just arrived at work), lately i asked where the hell did the supplier got those but it seems they were laying in his store for years
Those are the strongest and the best tweezers i have seen in my entire engineer carrier, one could even use them as a …everything, they will never break, snap, swap ot damage, very solid one, very russian Smile
Could you pls take a look and if you find those ,offer them to us, the next time i order pills from you will get at least 6pcs if the price is reasonable
kiriba-ru
kiriba-ru's picture
I suppose they are from medicine. I will try to find them in medical equipment shop (I knew that smth similar does exist but still continue using low-cost chinese tweezers).
chouster
I received my spacers yesterday. Looking good. Shipping was quite fast from Russia to Germany. Will report back when I have the first one installed. Thank you very much, kiriba-ru!
kiriba-ru
kiriba-ru's picture
giorgoskok wrote:
Can you say more for the “solid neck p60 AL” ?
Is this for triple or quad ?
Here is it:
imagebam.com imagebam.com
Neck+short tube=18650 light
To use 18350 (s), you need extra rings (number of rings=number of 18350)
I have only big rings that fit tail right now (made from SS). Later I will make smaller ones (to use them between tubes) and those one that can fit between neck and head (all from brass). Head side is little long, if you wont use ring between head and neck you need to sand it down a little or just put some o-ring there.
You can screw-in any convoy S series pill. Triple pill or single pill with spacer can be used to build quad with Carclo optics, single pill without spacer can be used together with some single optics.
You can use long tweezers to adjust pill position for optics height.
kiriba-ru
kiriba-ru's picture
Same in copper:
imagebam.com
External surfaces are not so good and require some polishing, but I dont have time to do this so they will be selling “as is”.
DangerNoodlez
Last seen: 9 months 4 weeks ago
Just received my package from kiriba-ru, color me very pleased. The spacer seems nice and everything was packaged very very well. He even shipped it in this nice little plastic box. Tracking was provided and accurate. Would recommend!!
Patiently waiting for packages from China.
vinte77
Last seen: 3 hours 30 min ago
I had a couple of questions about the solid neck p60 AL. Do you mean that, the neck + 18350 extension tube, head, and tail = you can fit a 18650 cell? Also I’m not sure if I understand what you mean by if you add extra rings you can use 18350 cells. Is that for multi-battery setups?
kiriba-ru
kiriba-ru's picture
Yes neck only is close to fit 18350 cell inside.
One 18350 cell is longer than half of 18650 cell length (and ext tube length), two 18350 cells are longer than one 18650 cell and etc.
So if you will use one or two 18650 cells, you will have enought space for cells inside and extra rings allow you to use protected cells.
But if you are going to use one, two, three or four 18350 cells you have to add at least one, two, three or four rings respectively.
Texas_Ace
Texas_Ace's picture
So many things I want to order but alas no money or hosts to use them with at the moment. Soon though……
vinte77
kiriba-ru wrote:
Yes neck only is close to fit 18350 cell inside. One 18350 cell is longer than half of 18650 cell length (and ext tube length), two 18350 cells are longer than one 18650 cell and etc. So if you will use one or two 18650 cells, you will have enought space for cells inside and extra rings allow you to use protected cells. But if you are going to use one, two, three or four 18350 cells you have to add at least one, two, three or four rings respectively.
Got it. Sorry if I missed it but I didn’t see the prices for the copper and aluminum necks, and spacer rings.
kiriba-ru
kiriba-ru's picture
I have made 2 of them from Al and 2 from Cu so this are test versions. They are not so pretty as I wish.
Anyway I cant polish them soon, I will try to sell them as is.
Some members have asked me about them, I will contact them PMs and make my offer.
So Im not sure that I have them on sale, I can say that they are already reserved, if those that asked about them earlier will refuse, I can contact you.
Nicolicous
Nicolicous's picture
Last seen: 59 min 34 sec ago
Got my orders today.
Thanks kiriba-ru.
Highly recommend your amazing work.
Happy modding and i will be back for more Big Smile
Nico -.-
hellokittyhk
Hi, I’d like to make an order for:
1x P60 copper quad drop-ins – Surefire non-compatible, no ground spring required, driver press fit/solder version.
1x triple liner with gitd o-ring
Should be $20 USD +shipping.
Still have some in stock? My paypal is ready Smile
kiriba-ru
kiriba-ru's picture
Unbelievable. You was waiting four years to write your first post in my thread?
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 26 min ago
kiriba-ru wrote:
Have very last xp-g3 s5 3c leds soldered to the x5 spacer. $26 for the kit that containes leds on tpad quad, copper spacer, ss liner, carclo quad narrow.
I’ll take it! Thumbs Up
KB1428 “Live Life WOT
hellokittyhk
Yes!
It’s taken years for cheap p60 pills to become available! No?!
kiriba-ru
kiriba-ru's picture
hellokittyhk wrote:
Yes!
How do you think, is here any need in stock design p60 pills in copper? Some drop-in manufactures using brass pill with xhp50, xhp70, driving up to 20W to the led. Not good at all.
hellokittyhk
kiriba-ru wrote:
hellokittyhk wrote:
Yes!
Yes I think that would be good. Some of us want high power in a single led with reflector setup.
In fact the last p60 pill I ordered was 4 years ago, it was a custom machined p69 screw in to fit a standard reflector.
kiriba-ru
kiriba-ru's picture
X6 SS version spacers and U11 kits will be ready in a week in work.
Next to produce:
- P60 copper pill (for single led and stock reflector, surefire-compatible, with driver retaining)
Thinking about:
- more ZY-T08 pills? Anybody interested?
- regular noctigon and tpad pcbs in stock?
- more Cute-3 optics in stock? Could be available with mass interest only.
- more specific (rare) optics in stock?
- tir+pcb decision for SRK clones? Could be available with mass interest only.
- illuminated tailcap decision (pcb with soldered leds) X6 style tail? Could be available with mass (very mass) interest only.
Also, thinking about offering small pieces of bare Al/Cu rod for cheap price.
Waiting suggests about new mechanical parts.
Llwyn
Last seen: 2 years 8 months ago
Hi. I made my first order here a while ago. Shipping was quick and took maybe six working days.
The items were well protected, some of the best packaging I’ve seen for a small parcel.
http://i.imgur.com/3AII11X.jpg
http://i.imgur.com/yN5Y5dk.jpg
Sadly I will have to wait much longer for my other parts to arrive from China and Hong Kong, so I can’t comment on how they work right now, but I’ll make sure to do an update later.
Thanks to Kiriba-ru for providing this service for people who do not wish to order from USA.
Llwyn
I saw your problem with PayPal, did you find any alternative or solution yet? While I don’t know much about AliPay, it does seem like a very similar alternative and I would expect many here to already use that service.
vinte77
Venmo maybe an alternative as well if PayPal is giving you problems
KawiBoy1428
Received my M1 Quad kits, S2+ kits and X5 kits, in perfect shape, a couple of the plastic containers took a beating but everything survived! Thumbs Up Great Job and thanks, kiriba-ru!! Wink
kiriba-ru
kiriba-ru's picture
I can change plastic boxes in pte bags to corrugated fiberboard boxes, but they weight 60gr more, so this is reasonable for big parcels over 250gr only. Usually such heavy orders cost more than small parcel limit, so I use this type of package rarely.
tekwyzrd
tekwyzrd's picture
kiriba-ru wrote:
> Parts that can be produced in different configs (any material, height, pcb size, driver size and etc.), but I won`t make them anymore if I`m not sure that members will order them: - SK68 clone pill - S2 single/triple pill - S2+ single pill - B158 pill - UF-1405/1504 pill - HD-2010 pill - ZY-T08 pill - screw-ins for Surefire E series - custom spacers
I’d order a s2 single and/or triple if available
Banggood – recommended for buyers who don’t mind an endless wait and continuous excuses for not dealing with defective items.
Fasttech – recommended for buyers who like to wait long periods with ever changing arrival dates for items that were ‘in stock’ when ordered.
tekwyzrd
tekwyzrd's picture
kiriba-ru wrote:
How much?
for the s2 single or triple? what’s a fair price to you?
