What did you mod today?
8805 posts / 0 new
WillyD
Last seen: 1 day 2 hours ago
pilotdog68 wrote:
Tonight I received my first lux meter.
So, what meter did you purchase? I’ve got a tab up with an HS1010A from Banggood in my cart.
pilotdog68
pilotdog68's picture
I ordered that same one from Banggood, but it showed backordered. So I cancelled it and ordered the same one from a US seller on eBay
ZozzV6
ZozzV6's picture
Last seen: 4 days 11 hours ago
I have that one too. Works fine. No problem.
chouster
So what about your L2, PD? Did charging up the battery help? I think you should see at least 150 kcd, even 200+ kcd is possible with high binned XP-L HI.
The XP-L HI in that L2 isn’t that hard to focus properly. I’ve done it three times. The first time I raised the emitter by soldering a copper disc underneath the MCPCB, but for the last two I went without that, but achieved the same well focused result.
For a L2 with dedomed XP-G2 I had to raise the emitter as well, that one was much more a PITA to focus as the XP-L HI.
I have another L2 that I wanted to build up for a friend (XP-G2 dedomed + FET-Driver), but ran out of FET drivers, so I put a sliced XP-E2 @2,1A in there, just for fun. Now that is a pencil beam. Since it was just for fun and won’t stay like that, I didn’t fiddle around with focus too much, probably should though, to see what it’s good for…
So now, I have three L2’s, one with XP-L HI, one with dedomed XP-G2, one with the sliced XP-E2. However, I’ll keep just one, still have to decide which. Would have posted beamshots that compare the three, but have only two working tail-caps right now, since one is in the progress of beeing converted to a reverse clicky. Not as easy as it sounds! I really dislike the stock forward switches, fried three out of five during the usual bypass operation.
pilotdog68
The cell in the L2 was a lot lower than I thought: 3.6v. I didn’t have time to let it charge last night so I’ll test it again tonight. I’ve been considering moving to dedomed XP-G2 in it, after these readings I might give it a shot.
I thought for sure my Courui would be above 300kcd, and I know the cells are for sure over 4v in that one. The focus being bad is the only thing I can think of.
That’s what I was worried with getting a meter, that it would make me unhappy with lights I previously enjoyed. For that reason I don’t think I’ll make a sphere or pipe. I mainly wanted the meter to measure before/after for the upcoming TM16 mod.
chouster
Haha, expect no wonders with the cell at 3.6V. I think with a good charged one you’ll have a reading that is much more towards 200kcd…
giorgoskok
giorgoskok's picture
Pd before changing something , measure the amperage draw . If it draws enough amps , then it’s a focus issue Wink
chouster
Well I still can’t decide what I like better in an L2, the dedomed XP-G2 with more lux or the XP-L HI with more lumen and better tint. I’d say the XP-L HI is more practical in use. The sliced XP-E2 is funny and maybe cool to have that kind of reach @ 2,1A, but not practical at all. One day I had a fox lit up maybe 200-300 ft away, I had to hold that light soooo steady just to keep him inside the beam… Dedomed XP-G2 is somewhere in between, but compared to the sliced XP-E2, even the dedomed XP-G2 is so much more practical.
I hear you on the measuring stuff, PD. I don’t like to measure the heck out of my lights, I simply like em or I don’t, don’t care much about numbers.
BobbyMK
BobbyMK's picture
Last seen: 3 days 23 hours ago
D01 with xp-g2 should be well over 300kcd. I measured mine at 305kcd and it is running dedomed xml2 u2 driven at ~5A.
I recently ordered Noctigon XP32 boards, would love to see what numbers will D01 give me with dedomed xp-g2, if i find a good one.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
pilotdog68
What do you guys think of the TM16 numbers? Do you think I need to adjust all of my numbers up, or is the TM16 just under-performing?
pilotdog68 wrote:
  • Nitecore TM16 – 105kcd – Stock (Nitecore rates 122.5kcd)
  • Solarstorm SP03 – 236kcd – Dedomed XM-L2’s, FET
  • Courui D01 – 231kcd – Poorly focused dedomed XP-G2, FET
  • Brinyte B158 – 230kcd – Dedomed XP-G2, FET
  • Convoy L2 – 130kcd – Low-bin (possibly poorly focused) XP-L HI, FET
  • Thorfire S70 – 99kcd – Shaved stock XHP-70, resistor mod ~9amps
  • Jacob A60 – 93kcd – Dedomed XP-G2, dirty lens, FET
  • EagleEye X6R – 14.4kcd – Dome-on Triple XM-L2, FET
  • EagleEye X2R – 8.8kcd – Low-bin XP-L HI, FET
  • Convoy S8 – 6.9kcd – Dedomed XP-L and dedomed XP-G2, frosted narrow optic, FET
  • Thorfire TG06 – 4.4kcd – Nichia 219c, 2.2amp driver
  • Olight S15R – 1.8kcd – Warm XM-L2, stock driver.
unknown00101
Pretty close to what I got. 111kcd. The TM16 utilizes direct drive for turbo so it’s heavily dependent on cells.
It might have been over 120 before the limiting voltage thing.
pilotdog68
I thought they would be using a fancier driver I guess. I’ll charge them up and try it again too. I need more chargers apparently
giorgoskok
Using original (stock) reflector ?
BobbyMK
BobbyMK's picture
Yes, stock reflector but i might be wrong about the current because it is direct driven, no driver at all, so it might be higher. At the time of the test i had three 25R’‘s in it, ive seen that same led pull just over 5A from a single cell, so with 3 in parallel there might be a bit more juice delivered to the led.
DB Custom
DB Custom's picture
Last seen: 6 days 23 hours ago
My TM16 is making 109.75Kcd, essentially stock… I didn’t change anything on the driver, still has the NW (on the warm side of NW) emitters, but I used 18ga Turnigy leads throughout, in place of the 20ga they used.
So I’d say you’re in the ballpark.
I’m using fresh charged LG HE-2 Button Tops.
Direct Drive for Turbo? Where does that info come from? I see an R010 sense resistor on the driver… mine tests out at a bit over 4100 lumens.
giorgoskok
As djozz explained me :
http://budgetlightforum.com/comment/1027012#comment-1027012
BobbyMK
BobbyMK's picture
Yeah, tested it, three 25R’s @ 4.19V = 5.7A at the tail, so there it is, it is more than 5A.
unknown00101
Probably misremembered DD.
Max did a really nice write up on the TM16.
http://budgetlightforum.com/node/40740
pilotdog68
With the lumens Nitecore quotes (4000), Turbo is probably like 2.8amps per emitter. It still could be susceptible to a tenth of a volt or two.
DB Custom
DB Custom's picture
My only remaining Courui D01 also uses 25R’s, it’s making 545Kcd with an XP-L HI for 1476.48M throw.
Not liking myself for selling the SBT-70 D01.
(gotta see if I can tweak it for that remaining 436 feet to make a mile. Big Smile LG HE-4’s will probably do it. Wink )
Edit: Best is actually from Efest 35A’s in this light, at 557.5Kcd for 1493.32M. Still some 381 feet shy of that elusive mile. Oh well.
-X3-
-X3-'s picture
Last seen: 1 day 6 hours ago
Today I swapped the emitter of my Olight S-mini :
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
djburkes
djburkes's picture
Last seen: 2 years 2 months ago
Lol…you made someone a very happy camper though. You were able to spread your joy elsewhere. My edc has been the X5 since I received it and it probably will be for a long time.
giorgoskok
545kcd using xp-l hi ? Sweet .
Also , anyone using the 86mm KD reflector in his D01 ?
unknown00101
How did you focus your D01 for that throw?
DB Custom
DB Custom's picture
Yeah, that little quad is a pretty dang sweet light, for sure. Dang sure won’t be picking one up at Wally’s World anytime soon… LOL
Terry White
Terry White's picture
Nothing yet but it is still early...
Terry White
Skype terrywhite1@live.com
DB Custom
DB Custom's picture
I cheated unknown. The “Big Head” Courui is now the Mega Fat Head Courui. Big Smile
153mm Seanna optic.
giorgoskok
153mm Seanna optic.
Ohh i remember now Evil
unknown00101
Shame Shame Shame. Wink Silly
I need to tweak mine. It was such a pain for me to mod it when I finally got it all together and properly centered I just left it. Low 200kcd’s iirc. Really disappointing for a FET XPL-HI in a Courui D01.
CRX
CRX's picture
Last seen: 3 min ago
CQG Carbon Fibre
