The reason there are so few accidents is because lithium cells are actually quite stable. The difference is that when abused outside of the design parameters (which are pretty extreme in themselves) they have the ability to create flames instead of “just” leaking acid or dying.
As far as the ones you do hear about, first off you will notice the vast majority of those are in custom sized/made battery packs for things like cell phones, not standardized 18650’s.
The reason those tend to have more issues is simply space, they are trying to cram as much power as possible into the tinyiest space possible and with the least weight possible. This combo leads to sacrifices in other areas and those can lead to much larger issues.
It is really the technology race having long ago outpaced lithium technology but there being nothing better to replace it so they just keep pushing it further and further.
1) It is nevertheless ironic that you don’t hear any accidents with these *Fire 4x26650 (or 18650 with spacers), 16xXM-L T6 21000 Chinese lumen light for 89 Dollars or something, and these suckers just don’t explode…
2) You all know how long it takes to charge lithium ion right? Ever noticed how quickly your phone charges? Ever notice that your phone gets fairly warm during charging, but your cells in your xtar charger (or any other brand) don’t get that warm at all (0.5A)? Get the feeling they (phone producers) are pushing the boundaries…
Yep, the pressure to get a heads up on the competition with the already very tough smartphone market has force manufactures to push things WAY past what they should. This usually works out ok, sometimes you get a note 7.
I’m actually going to be seeking a little wisdom from you as far as buck drivers go. I have two lights that I’m going to mod and each light is going to need a buck since the battery carrier is set up 4S. I’ve never stepped into the 12v realm before…only 3v and 6v and only with fets. However, I’m getting away from fets on these particular mods because of the setup. I’m use to piggybacking on contact boards and other drivers but have come to the realization that the bucks are going to have some kind of heat displacement. Would covering the driver with silicone or another potting material suffice…if it’s being used as a piggyback? Also, where would I get a buck driver that would push 2.5 amps to a XHP35 with an eswitch setup? I’ve got another light with the same setup but it’ll have an XHP50…where would I get a buck driver for it to push it to it’s max? I’ve also already had my ambien so if none of this makes sense, lol, sorry :weary:
I knew as I logged off, I was thinking did I saw 4S or 4P…, Well I was certain of one thing, I will know the answer to that when I log back on, and yes it is 4P so Thank You and by the way no need to be sorry about confusing me, I am an expert at confusing me
One thing is for certain with me and that is if T-A says the 4S is the way to go, and I think Tom says the same, along with KB, so 4S it is and I will learn the rest as it goes.
Maybe I should just go read on parallel and series applications more, back to basics, fundamentals,
I sure am not short on info being I actually have Google on my computer, I think it came with it when I bought it… Sure is handy.
I’m kidding ya, I paid extra to have it installed… :laughing: … but I do want to know more about this issue and well just about everything else also, …
Thank you for clarifying my mistake, I do appreciate that…!!
Yes indeed, I counted what lights I have in plain site, phone rang and last I recall I was somewhere in the high 80’s, I could probably times that by three and come out short, it is insane.
It get even stranger when your going to go out in the evening and can’t decide which light to take with you…
That HF bench vise is pretty good for the price, I’ve lost my rubber things that were worthless anyhow, just keeping up the maintenance at your house would be a full time job.
Edit: Speaking of vise, I put my MH20 head in the freezer last night, bench vise ready to go, darn glue, would have forgot had I not seen that vise… Thanks
I keep moving/reorganizing all my stuff==the keepers—for sale etc—the other day my wife was in the space bath dressing area—I said wait be careful there’s flashlight parts in there
