I have an early one (360 L), and just picked up the 240 lumen CRI version a few days ago. I’ll have to see if I can do a comparison. I have not had problems, but it seems the lockout mode on these lights is made for when you stuff it in your backpack, as opposed to long term storage. The light has to monitor for the key combination to unlock, and it’s only got a 500 mAh battery, so it’s almost asking for a dead battery. I’m glad they seem to have done something about it, and I’ll report back when I can do some testing between the old and new. Is there a way to tell if my CRI version is actually “new”, and not one that had been sitting around?
I think Nitecore fails to distinguish between two very different modes:
Lockout — no electrical drain, accomplished by physically breaking the circuit
‘Numbutton’* — the buttons are protected from accidental bumps, in some way, e.g. by requiring both to be held simultaneously. This requires some electrical drain.
*Yeah, I made that up. You can shorten it to two syllables, if you prefer.
I have the new version 2 Tip and put it on lockout for a week and didn’t touch it and after one week it still blinked 3 times when doing the battery test. So it’s definitely much improved from the original version.
I will say that the light hasn’t held up (as far as appearance goes) with standard keychain use. I haven’t dropped it once, but it looks pretty worn in only a couple weeks. Not a huge issue, just food for thought.
OK, I have been watching this GB since the beginning, and my CRI is on order and due to ship Nov 20. I have to ask, why is the drain from lockout (electronic) different from the normal parasitic drain that one sees in everyday use? From what people have said, they can go a lot longer just in normal mode between charges than when using the V1 lockout mode. This really doesn’t make any sense to me. Can someone enlighten me?
I had paint coming away from the corners on mine after a day in the pocket. Finish isn’t great. If you’re worried about appearances, buy a silver Tip would be my advice.
Doesn’t bother me especially as it’s a functional thing for me rather than a looker.
Yep, mine behaved the same way. Still functions perfectly which is all I really care about, but I figured I’d add my findings in case someone else cares about the appearance of their keychain light after prolonged use.
I got mine from the original batch from Illumination supply. Yes it does have the excessive battery drain problem in the lockout mode, but since I put it one a long lanyard and wear it around my neck, there’s no need use that mode. Also, since it doesn’t rub up against anything abrasive, it’s still in perfect condition. That all being said, I love mine.
Hey lads i have the Christmas edition. I love it! No lockout drain issues. The Standby current is a tad high mine read about 88 Microamps. But appears to be okay. I pulled it apart to have a look inside.
