I have the new version 2 Tip and put it on lockout for a week and didn’t touch it and after one week it still blinked 3 times when doing the battery test. So it’s definitely much improved from the original version.
I will say that the light hasn’t held up (as far as appearance goes) with standard keychain use. I haven’t dropped it once, but it looks pretty worn in only a couple weeks. Not a huge issue, just food for thought.
OK, I have been watching this GB since the beginning, and my CRI is on order and due to ship Nov 20. I have to ask, why is the drain from lockout (electronic) different from the normal parasitic drain that one sees in everyday use? From what people have said, they can go a lot longer just in normal mode between charges than when using the V1 lockout mode. This really doesn’t make any sense to me. Can someone enlighten me?
I had paint coming away from the corners on mine after a day in the pocket. Finish isn’t great. If you’re worried about appearances, buy a silver Tip would be my advice.
Doesn’t bother me especially as it’s a functional thing for me rather than a looker.
Yep, mine behaved the same way. Still functions perfectly which is all I really care about, but I figured I’d add my findings in case someone else cares about the appearance of their keychain light after prolonged use.
I got mine from the original batch from Illumination supply. Yes it does have the excessive battery drain problem in the lockout mode, but since I put it one a long lanyard and wear it around my neck, there’s no need use that mode. Also, since it doesn’t rub up against anything abrasive, it’s still in perfect condition. That all being said, I love mine.
Hey lads i have the Christmas edition. I love it! No lockout drain issues. The Standby current is a tad high mine read about 88 Microamps. But appears to be okay. I pulled it apart to have a look inside.
PSA: The TIP CRI is on sale at:
Battery Junction - $26.12 for a couple more days - no code needed.
Gearbest - $22.95 using their CPF code in the Dealer’s section of CPF.
illumn: Nitecore Tip USB Rechargeable Keychain Light 220 Lumens (CRI 5000K) code blacknovember brings it to $24.49
I bought the Nitecore TIP XP-G2 Cool White just after Christmas (2016) as I was told this vir had the lock out fix and went to use it when I come to going down some dark steps and nothing no power so the fix has not been sorted yet, such a shame as they are a great little light when they do work, just rang NC united kingdom to ask for a refund, its not good to me if it don’t work when you need it.
can anyone recommend a good key light that’s nearly as good maybe that works please?. Thanks
