Mine was waiting for me tonight after work.
Yup, beam perfectly centered.
At 1st, I thought that moonlight was not bright enough, but after playing with it
for awhile, I realize that moonlight is exactly where it should be.
This light is much heavier than I expected, and that’s NOT a complaint.
Beautiful light!
Rey, thanks so much for this!
Sounds good! I love my brass ReyLight Pineapple - that’s for sure. Just had it for two days - perfect lowest firefly level - nice mode spacing… a trit slot… what’s not to like?
Got mine today too. Really nice light. I have no issues with the PWM, cause I can’t tell its there at all. My only “gripe” is with the ring in the beam due to the two-stage reflector shape. Its a minor thing though. Loaded the tail up with an “icy blue” trit. I like it!
After all the chaotic tracking, guess what came yesterday? Yep, got it! The USPS tracking emails stopped, but tracking info is now updated - weird... Quality is excellent, threading silky smooth. Not a fan of the button feel - mine is very loose, wobbles around - I'll have to take a look inside to see if there's an issue there. For the pics above, mine seems to have a bigger gap of space around the SS button. No one seemed to complain about it so maybe it's just mine.
The beam is more white than expected - doesn't look like Gunga's beamshots, but that's just a first impression - need to compare with other tints I have in 219B's and 219C's. I know 4000K CREE's would look more yellow. I already received the 4000K 219C's I ordered separately, so could install one and compare.
Overall outstanding though. I'd say my initial measurements of amps and lumens match up well to Dale's, just lower across the board because I used a not so good 14500 cell - MXJO.
I got a pineapple in the mail. I haven’t had a lot of time yet to measure it, or even take it apart, but here it is next to its brass siblings: (late-model CNQG brass 18650, original CNQG brass 18650, Reylight Pineapple, CNQG brass AA, DQG Fairy)
It hasn’t had time to age yet… is still pretty fresh brass.
I did try to measure the PWM though. What I found was:
Moon: no visible PWM
Low: ~770 Hz?
Med: 1.77 kHz
High: ~2.0 - ~2.2 kHz
The only level with a solid “lock” on the frequency was medium; the others are estimates from a signal my meter had difficulty measuring. I’m also not sure it got an accurate number for the low mode, though visually it did look like low was slower than medium.
Another quick pic. I noticed that the different brass finishes were more visible in a different environment. Also, it looks like the head of the Pineapple may have spent more time exposed to air than the other pieces. However, that should all even out after I’ve had a chance to weather and polish it.
You can see a close-up of the surfaces here, or a zoomed-out view below.
For the button, what I did was move the rubber boot inside the collar instead of outside, as it came. To me it feels a bit better, works well. I added some Nyogel where the cap makes contact to the brass collar and the end cap assembly. There's still some wobble but I find it acceptable.I fiddled with a couple o-rings in various places, but it took away the button press ability - not a good thing, so I didn't pursue the O-rings any further.
The tint is a bit warmer than Nichia 5000's I have, but wow, it looks so good for a 4000K LED...
Now all I have to do is add the trit that's been wait'n.
Got mine the other day and it is a beautiful piece of craftsmanship. But I can definitely see the PWM. Rey, if you end up producing a revised driver at a faster rate, I will definitely order one.
