Yeah, but without the battery, because apparently the tube and spring add 1.3 Volts to it, so you should measure the voltage over tube and spring.
So if you can, stick the (+) probe inside the tube touching the spring.
It should read 1.3 Volts somehow.
Speaking of LSD, maybe there’s some acid in the bottom of the tube, maybe from a leaky alkaline?
I don’t know what voltage aluminium and chrome produce, but that could be it.
Does the light work properly?
Looks like you are taking the second, higher, reading with the cell installed and the head off. Looks like the driver is not in the head but in the body and is boosting voltage so the LED can light up. This is the only way a NiMH or AA can work in a flashlight with a single cell. Pretty much everyone who posted before me knows this as well so I must clearly be missing something here. In the second pic are you measuring at the tail with the tail cap off or at the front of the battery tube with the head off? It’s really hard to see exactly what you are doing.
Jerommel, do you think this magic can power the LED on this flashlight (i3s) if connected without the battery (of course I have to use some sort of dummy AAA)?
Asking this because the flashlight wont turn on with this 2V+ but when I use different i3s battery tube, the head is fine.
