4 x single 219C 90CRI 4000K on 16mm copper MCPCB
4 x single 219C 90CRI 4000K on 20mm copper MCPCB
2 x triple 219C 90CRI 4000K on copper MCPCB to be used on S3 hosts
- 144A doesn’t have thermal pad built in. And there’s very limited options available at the moment. You have to use custom MCPCB like VirEnce or Djozz board. The easiest way is to find board designed for 119A. Then you need to scrape off the solder mask to widen the pads. I haven’t seen 119A boards for triple too.
Triple 144A would require 18V - driver problem
144A is already 4 x 219C crammed together. You should get approximately the same output with quad 219C.
The most benefit of 144A over 219C is higher max output, simpler single optic source point, higher quality light above 4000K region. It has fatter (almost 40%) spectrum in 480nm region, the area most cool white LED lacking
Texas Ace, my current order is 4x 219C 4000K.
Can you add 4x 219C 3000K to my order.
Please pm me your paypal and total so I can get the funds to you asap.
I assume paypal gift is preffered to avoid fees?
Shipping of my LEDs will be to DB Custom.
Thanks!
