I have the Olight X7, its nice but pure flood. Pretty impressive. You would need huge reflectors to get high intensity beam with a XHP-70. Even the Convoy L6 which has a huge reflector isn’t big enough to get the same throw as the TM26GT. The TM26gt is compact. I did wish it had something like 5000lumens though.
There is a TM28 on the way. 4xXHP35 HI for 6000 lumens on turbo, and steps down to 2300 lumens IIRC. Lux value is over 100k, but less than that of the TM26GT. They say you actually need high drain cells for this one to get the 6000 lumens. I’m totally fine (at the moment) with the TM26GT.
In the dark flood monsters like X7 are contraproductive when it comes to throw
They might light things as bright as a 1/10 power semi thrower but you cant see them because the wall of light close to you
they are so bright your night vision gets totally busted, while on a sharp thrower you can actually see things far away at a lot less lumens illuminating it
Well looks like the TM28 will be same chassis as the TM26GT. So if the TM26GT steps down because it cant handle the heat of 3500lm for too long, then the 6000lm will be even less runtime. Im happy with 3500lm.
Grat thing for Rofis discount,maybe they could push it little more,48$ is still expensive, but I have one in the box,and waiting your code.
Main reason I like it is the same UI like Olight M3XuT, actually driver looks the same….
Hey folks just added Nitecore TIP Christmas edition. Makes a great gift for all. This package has every thing you nee to use and run the light straight out of the box. Cheap price 22 USD…
Package Contents: 1 x Nitecore TIP Christmas Edition Keychain Light, 2 x Keyring, 1 x USB Charging Connector, 1 x Gift Card, 1 x Gift Box, 1 x English Manual
Thank you very much Everydaysurvivalgear.
I got Nitecore TM26GT, EA45S and TIP (I just became the member of BLF then lost arm and leg for flashlights! :person_facepalming: ).
Hey folks Gearbest asked me to update some deals while they are away so i will post deals that i think are good i guess.
Convoy L6 black are $50.99. This is for both tints 6500k and 5000k this is limited to 100 pieces! I tried code doesn’t work on the clear! False advertising by me lol L6 black
Price:$50.99 Coupon:CL6GB
UTorch UT02 appears to both tints also 6500k and 5000k. UT02
Price: 39.99 Coupon: UtorchDeal
UT01 is on sale i think its the same price as the Group buy. No photo for this one lol I was meant to review one but never did!
