PM sent, thanks for offering this!
I have notices in a SMO P60 with a Nichia led that this is like a night and day difference. I have also installed on in a SMO S2+ with and XP-L HI and OMG it makes the beam so perfect! I am going to have to order more of these.
This is a wonderful product!
Mine arrived today. The drop-in I added it to didn’t have any major artifacts, but it still did a nice job of smoothing out the beam. Very nice lens.
Pflexpro thanks for offering it!
This would be a great Lens for the Q8 Flashlight. At the moment i can not find the dimensions. But if the price is right there is much potetial for a big sale (~ 800 people are on the interest list). Because at the moment they are using a plain glass lend without any coating.
The price for a big light like Q8 would be more than the light itself
How could I have missed this innovative lens?
What sizes are possible?
Could this be a aftermarket lens for the Q8?
I am not sure about that!
A ~30mm lens cost 4,5$. I do not have the exact dimensions but it has to be somthing about ~47mm± a few mm.
Sure it will not be for 5$ but I’m pretty sure it will not cost 40$.
And if its in the 10-15$ range i would be definitely interested.
Hope that i can get the exact dimensions soon.
For the Q8, could someone provide the lens dimensions. The only thickness I currently have the Micro-Textured AR material in is 1.5mm, but this thickness may be suitable for cutting a few for evaluation in the Q8.
(I have a few sheets of the MicroTextured-AR 1.5mm coated but uncut.)
The Q8 probably uses a 2mm lens… I will be getting a quote for a few sheets of the 2mm material AR coated an cut to C8 size.
Does the Q8 need the MT-AR lens to clean up the beam or does it just need an AR lens? The plain AR will be easier and less expensive.
The only existing Q8 prototype has a lens size of 55.1 mm x 2.81 mm, but of course doesn't have to be an exact size replacement. No guarantee the eventual production unit will have the same lens size. We requested a width of 2.25 mm but it didn't happen.
I was interested in the Micro-Texture to smoth out the beam from the 4 LED´s.
The AR coating would be a nice thing to have but for me the Micro-Texture is far more interesting.
But the final price will tell if it is something worth to consider
So no love for the 28.6mm lenses, to fit SureFire bezels?
Offering any more MT lenses? I missed your earlier posts?
Got my lenses in a couple of days ago but just had time to install one. These are great. Its not a huge difference and probably wouldn’t clean up a truly terrible beam, but for the lights I put it in the lenses gave a very pleasing softening affect to the beams. I’d buy a bunch of these if you made them available in different sizes.
Speaking of which, I’d like to request one for my ReyLight Pineapple. I really like this little light but the “stepped” reflector makes for a distracting ring in the spill. I feel like one of these microtextured lenses would fix it right up, or at least help a lot. Seriously I want to buy one for my Pineapple. Hit me with a price and I will pay it! I bet others would too. Let me know if you need the dimensions.
I’d buy a Pineapple lens as well.
+1 - me too for my Pineapple. I've added a trit, so why not a top of the line lens? I'm sure he'll need dimensions.
Custom sized Micro Textured lens:
If there is enough interest in custom sizes, I will have 1 or 2 sheets cut into any size you want. The only material I have available is 1.5mm thick… I should have some 2mm in a few months.
You will be able to specify your size for as few as 1 lens or as many a 1 gazillion lenses, but remember, it will be 1.5mm thick.
It looks like the Pineapple uses a 1mm lens, so someone will need to decide if the 1.5mm will work properly.
A C8 usually has a 2mm lens, but the thinner 1.5mm doesn’t seem to be a problem.
For Surefire 6P, the diameter should be 28.2 -if you request a 28.2, I will include the o-ring I use when installing the 1.5mm lens in a 6P.
If you want the lens for Solarforce (29.45mm) or the S2/S2+ (20.4mm), do not request them as a custom… I have them available and they are cheaper because I had them cut in mass.
The cost will be a little higher for the custom cutting and possible lower material yield. When I have the lenses cut, it’s always 1 size per sheet.
When specifying your size, measure the diameter in mm and specify to .1mm. (i.e. 28.2mm). I will have the lenses cut as ‘not to exceed’, so the final dimension may be slightly smaller.
I have devised a formula that will allow you to price out your lenses (use mm for the radius): 2+((πr²)*.0075)=$ plus $1 per order ConUS - plus $2 per order international.
Big lenses will be expensive and I don’t recommend it for anything larger than a C8. With that said, I’m going to have one cut for my L2… I like what it did for my C8 so much, I just have to try it.
So, who’s interested?
It will take at least 75 lenses to make a custom run feasible, so let me know who’s interested.
I'll be interested in a few, but have to take measurements this evening at the earliest. I want 2 for the Lumintop Prince (brass & copper) but they may take your standard 20.4mm x 1.5mm size, then I'll have to check if 1.5mm thickness is ok for the Pineapple. Definitely would be interested in a couple more (OTR M3, M6, JetBeam Jet I/II MK, etc.) but have to check thickness's if 1.5mm is ok in them as well. I have no shortage of lights
So for a 40mm wide, lens, I calculated $11.42, plus shipping: 20*20*3.1415*.0075 + 2, if I did this right.
For the mathematically challenged:
diameter
(mm)
14 - $ 3.15
15 - $ 3.33
16 - $ 3.51
17 - $ 3.70
18 - $ 3.91
19 - $ 4.13
20 - $ 4.36
20.4 - $ 3.00 S2/S2+
21 - $ 4.60
22 - $ 4.85
23 - $ 5.12
24 - $ 5.39
25 - $ 5.68
26 - $ 5.98
27 - $ 6.29
28 - $ 6.62
29 - $ 6.95
29.4 - $ 4.50 Solarforce L2x (includes o-ring)
30 - $ 7.30
31 - $ 7.66
32 - $ 8.03
33 - $ 8.41
34 - $ 8.81
35 - $ 9.22
36 - $ 9.63
37 - $10.06
38 - $10.51
39 - $10.96
40 - $11.42
41 - $11.90
42 - $10.39 Convoy C8 (includes slightly thicker o-ring if needed)
43 - $12.89
44 - $13.40
Well I’m definitely interested in a Pineapple lens. I think the 1.5mm thickness will fit ok, but it may take a little thinning of that thick led centering ring to make it all tuck in there, and I’m not sure what that would do to the beam, but I’d still like to try it.
