Hello guys, today I present a torch unique and truly innovative, sent for testing by Imalent. Thank you very much! Here’s the IMALENT EU 06 “shark series” !http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1164_zps61f0e0a4.jpg ! SPECIFICATIONS:
• Spot light uses Cree XM-L2 (U2) and LED flood light uses Cree XP-G2 R5 LED neutral white LED with a lifespan of 50000 hours • 147.5mm (Length) x 25.4mm (Diameter) x 82mm (Head Length) x38mm (Head Width) • 167-gram weight (excluding batteries) • Digitally regulated output - Maintains constant brightness • Reverse polarity protection guards against improper battery installation • Intelligent thermal control to protect the flashlight against over-heat • Multi-functional LCD touch screen display running the specified level and the remaining powerwith low-power warning • Anti-roll and slip-resistant body design • Independently controlled lighting heads permit easy and fast operation • Made of durable aircraft-gradealuminum • Premium Type III hard-anodized anti-abrasive finish • Toughened ultra-clear glass lens with anti-reflective coating and quality PC lens The torch arrives home in a cardboard box imprinted with the general specifications above. The inscriptions are in relief, and give the box a good feed of robustness and quality. Open the box unthread the plastic package and find all ’internal instructions for the use of the torch in English on the one hand, and on the other side in Chinese. There is a card for the warranty provided by the manufacturer, an envelope containing an OR of reserves and a protective film for the touch screen.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/IMG_20140720_115415_zps2056d047.jpg !
We also find a nice Cordura sheath with logo IMALENT well built, we can mount it on a bag with MOLLE attachments or belt, or via a carabiner to hang it ’plastic ring at the top.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/IMG_20140720_122846_zps086419b1.jpg !
Well, now we take the torch in his hand and analyze them in his points, we can divide into 2 main parts:
BODY
the EU06 has a total black anodizing Halll, has a great touch and feed the sense of robustness, but seems to hold up well to shock and slightly slippery, looks like the anodizing of new nitecore. The rest is well done. The materials are of really good quality, give the torch a sense of incredible strength equal to ThruNite catapult. The machining is precise, clean without smearing, checkered checkered grip allows you to use the torch, even with gloves without slipping. The tailcap of light gray color, it allows the tailstand smoothly and has a threaded hole for mounting on a tripod. (I contacted imalent because the hole for the stand on my model is not UNC 14/20 but otherwise, this “bug” will be corrected by the house after my report.)
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1200_zps74fca039.jpg !
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1201_zpsedd5ce89.jpg !
The thread that joins the head is of square section with 5 coils, flow smoothly without blocks or games, immediately after there is a groove for the OR of good size that insulates well from water and dust. Everything came well lubricated and clean, without any residue processing. The thicknesses of about 3mm confer excellent resistance and solidity to the whole length of the body, light enough where ’inside we find a narrowing that becomes 18.5 mm by 22.3 mm and serves to accommodate the batteries which otherwise would 18650/cr123 game. On the bottom we see the pbc spring with a really thick gold plated. The body allows the entire tailstand torch.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1205_zps78d77967.jpg !
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1204_zps193b25ff.jpg !
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1206_zps2d00919e.jpg !
HEAD
It has a rectangular shape generously sized and heavy weight, as has 3 LED, 2 function keys and the touch display. On top there is a crown protection steel with matte finish that prevents reflections, has protective function of anti-reflective glass with transmittance of 98%. Thicknesses also here really generous and the good number of dissipating fins, maintain the torch at a temperature of use at maximum power really low, about 48 ° C using the LED xml2.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1203_zps51ec6dc8.jpg !
We analyze its 4 sides
1 Side
with buttons dedicated to the ON / OFF the flashlight and its hidden features strobe-SOS beacon. The keys are embedded in a ring of anodized aluminum with a matte finish all rotate freely and have engraved on the function they perform. The M key to cycle through the hidden mode and press the ON / OFF with the same symbol. The buttons are easy to press and give a feeling of “click” similar to the mouse buttons. We also see that is the word Imalent laser. Well done to the touch and deep, with great precision.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1210_zps2d1a6e99.jpg !
2nd and 3rd Side
with LED XP-E and XP-G2, respectively, Neutral White and Red. Dedicated to the function of flood flashlight, you can see the LED die in the bottom of the TIR lens with a slightly matte finish all held by a ring of anodized allumninio. We also see the cooling fins.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1209_zps0b4089ed.jpg !
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1208_zps7c01be5e.jpg !
4th Side
display with touch screen, which is managed throughout the Ui torch, all is well embedded in the head to protect it from damage or falls, has a protective film against scratches . The dimensions allow its use even for those with large hands. We also find the lettering laser-written with the model.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1211_zps19aebecf.jpg !
The torch has a kind of parable Smooth deep enough to allow a good throw of about 16k lux / m, the LED XM-L2 is well centered. From all fathers are opposite the spring contact gold plated, all held in place by a plastic ring and an aluminum cap.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1207_zps784f5045.jpg !
-LED-DISPLAY INTERFACE TO USE
!http://www.imalent.com/en/upload/file/images/20140622231500.jpg !
This EU06 is designed for a good range of uses since its ability to issue 2 different light beams more red one. The main LED is a XM-L2 U2 from tint Coolwhite coupled to a parabola Smo of considerable size allows thanks to 900Lumen ANSI have a good throw of 200m actual. The spot is well defined with an aperture of 10 ° and fades into a spill about 50 ° with wide enough to allow for optimal peripheral vision, without blinding the user. From my testing the torch in its highest mode and with a cell 2200mah fully charged it stops after 1h34m thanks to the stepdown that the torch will to protect itself from further damage due to heat.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1162_zpsdd26440e.jpg !
At the side of the LED flashlight we find secondary XP-G2 from a neutral tint and pleasant, with well 290lumen ANSI Power and frosted TIR optics allow a flood beam artifact-free and evenly blended, about 110 °. After a week of using this is perhaps the LED I used more during evening walks, I have used as a light source for photographic subjects experiencing a great success. From my testing the torch stops with a 2200mah battery at full load after 3h41min.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1160_zpsdec34bcc.jpg !
On the opposite side an XP-E RED will allow us to have a beam similar to the flood but red light, you notice a spot slightly more pronounced because of the smaller LEDs. The red light might seem almost useless unless you go hunting or whatever you think has a more specific role, but to my surprise I noticed that if you use it to walk in very dark places or take walks in the house without disturbing the sleep of others, and far more effective than a white led.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1159_zpse99ff989.jpg !
Now for the most awaited and important piece of the torch, his touch DISPLAY. The touch of the EU06 is 30mm x 16mm, from here we can control the flashlight in all its functions. It ’a touch of the resistive type high sensitivity and precision. The brightness allows us to read the data well written above and does not bother the user, even if in complete darkness. Lighting it appears: - Logo IMALENT - Battery Status indicated by 3 notches to go out on the basis of charge of the cell 18650. When the notches are all turned off the torch will have another 10 minutes of runtime.
!http://www.imalent.com/en/upload/file/images/20140605191547.gif !
- The mode key, with which we will select the 3 LEDs according to our needs Throw-Flood-Flood Red. The sequence is cyclic then starting from the LED XM-L2, pass it to the XP-E LED RED and then led to the XP-G2 and so on. - Lines for the adjustment, allow a constant adjustment of the brightness by up to 1lumen 900Lumen for the main LED, from 1lumen to 290lumen for the secondary. The red LED does not have precise data issued from the house, we can intuirli watching a Datasheet of Cree and doing calculations 2. About 0.5lumen and max 120LUMEN !http://www.imalent.com/en/upload/file/images/20140605191409.gif !
The control lines 17 and each allows us to increase or decrease the brightness, we can say we have some sort of infinite brightness. Also will make an animation with a consequent decrease in brightness when you have the battery from the display marks only 2 more notches, from 17 lines to 14 lines will pass you will lose about 100lumen. This is to preserve the torch and batteries with an increased runtime. I remember that when charged the torch will remain for 3 minutes and then turbo will make this step down. !http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1163_zps6b49bb5b.jpg !
The display will turn off automatically in 30 seconds after you turn it off or by clicking the physical button M located on the opposite side of the display and above the ON / OFF button. To reactivate it made a click of the button M. The torch also has a total block to prevent accidental starting, it will be enough to hold down the two physical buttons (M & ON / OFF) and the flashlight will emit a flash and then crash. To unlock, repeat the procedure and return to your last setting. In summary by pressing the MODE button cicleremo the LEDs and the LINES or will increase on decreasing the brightness. At shutdown will remain completely unchanged since the EU06 has the memory for each LED and power that we are going to select. So we can adjust the torch for our needs. To access the hidden mode simply click and hold the M button and start physical cyclically-Strobe-SOS-Beacon Steady, these fully adjustable from the display. One defect is that using these modes and changing the brightness, you lose the memory of the LED XM-L2 will turn to the level previously selected for the mods. disk.
BEAMSHOTS Pictures taken with ISO200 - 3.5 F - T 1.3s Tree 10m
XP-G2 NW
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1226_zps09546aff.jpg !
XP-E Red
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1225_zps9978847c.jpg !
Imalent eu06 XM-u2 L2 hig
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1223_zps32e4bf14.jpg !
2.0 Armytek predator g2
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1224_zps72398073.jpg !
100m open field 2.0
Armytek predator g2
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1219_zpsab49e5b0.jpg !
Imalent eu06
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1221_zps7524c69d.jpg ! CONCLUSION :A torch really interesting from a technological point of view, the touch display to a totally new experience in this field, leaving everyone stunned and is convenient for various functions, modes of spot light and throw. Very few twists that make it possible to cover more areas and needs, and the EU06 IMALENT it does it great. Sometimes she also has a small flaw, but in my opinion is completely negligible.
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1157_zps26bac095.jpg !
!http://i1276.photobucket.com/albums/y464/Danilo_Natali/\_IGP1165_zps64b9c6ba.jpg !
PRO: -Technological Innovation -Brightness adjustable at will –3 Led independent for 3 different situations -Fastness of materials and torch.
CONS-Weight with batteries a bit high and unbalanced in the head -Hole for Tripod wrong (it will be corrected by the house) -Thank you for listening to Dan-hilo89
