It’s been there for weeks, if not since they put this product on. I know that because I’ve been eyeballing this light for a while now. Easy to miss though.
I saw it too and was hoping to get the black cap. The only convoy I have received with a green cap was a host. When I see the green caps on a flashlight on someone else’s site I wonder if they built it from a host.
Received mine today, the host itself it is genuine Convoy S2+ but the driver is not standard Convoy driver, although it is same basic 7135 based driver it is a bit different from other convoy lights i have/had.
Driver is labeled as FX-12 and it has different PCB and spring than the standard Nanjg 105C/105D.
I modded this light after owning it 10 min. Reflowed the stock led on noctigon board and swapped the driver for a 105c with 12 7135 chips, 8 stock + 4 380mA. Tail reading with DMM shows 4.21A with 25R.
Was it worth for the price? Yes, especially when i paid only $7.5.
Everything is fine, led is Cree xml-2, driver works fine as any other 3/5 mode driver. I swapped my driver cuz I was to lazy to add more 7135 regulators on it.
But the driver will have to be able to rotate along with it, without getting in trouble with the LED wires.
I would prefer a thin enough ring over a notched one for that reason.
I ‘dremeled’ one out not long ago, does the job fine without getting in the way of the 7135s (nanjg 105)
Exactly right. So you need to twist the wires in reverse direction; then they will untwist as you turn the threaded ring and driver to tighten the driver down.
Yes, you can remove all the ‘overhang’ rather than just notch that part, leaving the threaded part unchanged.
I’ve ordered one 2,5 week ago, (and ordered a DTP with nichia 219c to make my first build/swap) still waiting…
The 30Q’s i ordered at the same time from GB were delivered after 10 days! That’s the fastest delivery from China i have ever had!
