I found the anodizing fine on the black and the grey one. I liked the grey one because it let you see the lines of the light better. I think I got a black one from a member here that was broken, he gave it to me in fixing another light up. I built it up with ramping firmware I think, it was pretty neat.
The grey one was bumped, newer style emitters, I even got a new optic for it but it’s in my kit here, a basic triple with a wide flange around it to fit in the largish head. I liked it, always thought that extra space in the head was odd. This 7 emitter light in a smaller head is really awesome, couldn’t resist!
I don’t recall the ano being shiny, but not the flat matte either. Just a normal decent ano as I recall.
@djozz @pinkpanda3310 @RobertB @Gerrit @zeroair @DB Custom @chooma @blueb8llz @Gunnerboy @Ray-o-light and the rest.
Thank you for your continued support!
A specially designed PMMA lens forms the ideal illumination range
Lamp GITD luminous effect
Tail inverted mode
Anti-anti-over-discharge protection
High reliability of the waterproof design
Compatible 26650 Battery Size: 26.8 mm maximum, the maximum length: 70mm (not recommended to use the 26650 with a battery protection, may be due to excessive battery size and circuit current limiting protection can not be used normally)
Using CREE XPG2 high-power high-efficiency LED, life expectancy of more than 50,000 hours.
Advanced high-efficiency constant current control circuit, with 4-speed output Brightness:
Very bright: 2500 lumens (90 seconds after the turn highlighted);
Highlights: 800 lumens / 2.5 hours;
Medium bright: 250 lumens / 8 hours;
Low light: 8 lumens, 200 hours. (Data to 5000mAh capacity battery as a reference)
Operation Guide:
Unscrew the tail cover, a 26650 lithium battery specifications above the positive into the lamp body barrel, tighten the tail cover, this time the torch is in standby mode.
In the standby mode: click the side button to open in the light; double-click highlight; three low-light; long press 1s open super bright.
Double-click on the super-bright, 90 seconds after the shift down to highlight (during the click or double-click to exit the super-bright to return to the previous stalls); click on the switch after the implementation of low-medium high cycle, let go to keep the current selection; Shutdown.
Precautions:
Ultra-bright stalls heat a huge, careful not to continuous dimming to ultra-bright stalls.
Forbidden to use the child is strictly prohibited direct exposure to light or other people and animals, eyes, light will cause discomfort or even injury; strict close exposure to the skin, so as to avoid being burned or allergic reaction.
The use of the lamp can not be shaded spot, or flashlight on the cover placed on the desktop, super light and heat output may cause flashlight and related items overheating or even cause
NW is out of stock now til the 18th. Ordered a gray CW that says 6-9 days to ship - not sure if any better, but specs direct priority shipping option for $1 extra.
