The review will be posted tomorrow . But here is a sneak peak :
UI : Ultra low - Low - Medium - High and hidden Strobe - Sos - Beacon mode
From off :
Single click (short) turns light on , on the lowest mode
Longer click turns light on , on the last used mode (not available for ultra low mode , because you can access it with short click)
Double click turns light on strobe (you enter hidden modes)
From on :
If you are in a regular mode :
Single click cycles between (Ultra Low - Low - Medium - High)
Double click and youâre in Strobe
If you are in a hidden mode :
Single click cycles between (Strobe - SOS - Beacon)
Double click and youâre in last used regular mode
Also , max lumens on High , using 14500 should be ~600 (to be confirmed in review) .
Doesnât fit protected 14500 as some people said .
Thanks a lot for the first impressions! It tentatively is looking very good.
Is this similar to to the E11 with the battery you are using? Budda suggests that âyouâll need high quality IMR 14500â in his review of the Manker E11, which had considerably higher output, but might be a battery difference:
