KD (kaidomain): Deals and new products thread
It comes with an optic.
Would a Carclo be significantly better?
I think all the KD triple emitters come with an optic.
Been staring at the KD optic and the pic of the Carclo on Mtn. I can not see any differences, really look identical too me. But I don’t have the KD in hand to check on a Carclo.
Well quality is one thing, but what about dimensions? Is it the same as a Carclo? Otherwise it may not fit well in the S2+ (or some other light).
It fits the S2+ just fine
Good to know, thanks!
It’s 20mm in diameter.
The uniqe difference betwen Carclo and Kaidomain lenses are the diameter of their legs inserts (the part which fits inside MCPCB holes).
KD´s are bigger.
[quote=PH_Oton] Kaidomain-s optics doesn’t fit into Noctigon 3XP MCPCB because 3XP is designet do accept Carclo optics ( narrower “legs”) so I widened leg-openings with Dremel in order to fit “unsuitable” optics [/quote]
I haven’t measured scientifically, but it seems the KD triple optic has more losses than a comparable Carclo. That’s just what my eyes tell me.
Can I get this KD optics as replacement? In my heavily used EDCs I need more than one optic a year.
Maybe put a glass lens over it?
Thought about this, but the additional lens eats light and gets scratched too. Carclos are cheap.
IDK about light losses, i was talking about diemsions, but that is also something to keep in mind.
Lens is at KD as a replacement.
Ceiling bounce comparison between KD and Carclo.
Does KD ship 18650 to the Philippines?
Hi
Yes, We had shipped the battery to Philippines.
If you order less than US$15, please pay $2 more to upgrade to registered airmail to have the tracking information.
Thanks
Ban
Hi friends
CREE XP-L HI V2 3C 5000K is in stock
http://www.kaidomain.com/p/S024502.Cree-XP-L-HI-V2-3C-Neutral-White-5000K-LED-Emitter
with 16mm DTP Copper MCPCB
http://www.kaidomain.com/p/S026430.Cree-XP-L-HI-V2-3C-Neutral-White-5000K-LED-Emitter-with-KDLIGHT-XP-16-16mm-x-1_5mm-DTP-Copper-MCPCB
with 20mm DTP Copper MCPCB
http://www.kaidomain.com/p/S026431.Cree-XP-L-HI-V2-3C-NW-5000K-LED-Emitter-with-KDLIGHT-3535-20-20mm-x-1_5mm-DTP-Copper-MCPCB
Thanks
Ultrafire UF-3000
This slipped by me . Reminds me of the old Ultrafire UF-5C lights that I think quite a bit of!
http://www.kaidomain.com/p/S024757.UltraFire-UF-3000-Cree-XHP50-White-2500-Lumens-5-Mode-LED-Flashlight-Black
This one draws my attention:
http://www.kaidomain.com/p/S025088.D170-Cree-XHP70-Neutral-White-4000K-4000-Lumens-Stepless-Adjusted-Diving-LED-Flashlight-Black
But how will the PWM be?
Not sure aboute PWM but paralistic drain would be high with that switch
BTW nice looking …
Possibly, yes…
You can put a main switch in the tail though.
Yeah, i thought so too.
But i don’t feel like gambling on the PWM.
Visible PWM is a deal breaker for me.
