giorgoskok
(giorgoskok)
December 10, 2016, 10:45pm
4
Overall impression is really good Very small light , capable of great output , for a small time of course ( limitations are : the capacity of the cells and of course the small mass of all the lights of that size )
Edit : longer cell i have is 50,6mm and works fine .
sb56637
December 11, 2016, 12:52am
5
Very nice, thanks for the detailed review!
Any idea on parasitic drain from the e-switch?
Freedom
(Freedom)
December 11, 2016, 2:38am
6
“_High (Efest 14500) : 42 minutes (until first “LVP” warning)
When battery voltage is below 3V drops to the lowest mode
High (Eneloop AA) : 55 minutes (until shutdown)
When battery voltage is equal or below 1V shuts down_”
Is it common for the LVP to keep on draining an unprotected Lithium Ion battery while a NiMh cell is simply shut down via the same LVP?
peteybaby
(peteybaby)
December 11, 2016, 2:40am
7
Thanks for the review! A few questions for you:
is there a lock-out feature, so that it won’t turn on in a pocket?
can you give us just a brief qualitative description of the mode spacing both with a nimh and a 14500?
does it seem to have fairly flat regulation (output remains fairly constant) or does it dim gradually?
how slowly do you have to single-click to change modes, without accidentally engaging the strobe modes?
mattlward
(mattlward)
December 11, 2016, 5:22am
8
How much PWM with this one? I would also like to know if it has a lockout mode.
Thanks Matt
arow55
(arow55)
December 11, 2016, 7:44am
9
Syrbuff has a youtube review on this light.
giorgoskok
(giorgoskok)
December 11, 2016, 8:27am
10
sb56637 , as i mentioned on the review it it 0,014mA .
Freedom , it is designed from the factory like that i guess .
peteybaby , No there isn’t lock out mode . It has a fairly good regulation , no visible dimming , until battery is not able to provide the required current of course . Only if you press the switch for a second time exactly after you release the switch it enters strobe .
mattlward , i will measure PWM frequency tonight .
agent80
(agent80)
December 11, 2016, 10:16am
12
No lockout mode? I thought the light would lockout if the head is half turned?
giorgoskok
(giorgoskok)
December 11, 2016, 10:46am
13
Yes , this is phusical lockout (if light has anodized threads , as ut01 has).
cdjaney
(cdjaney)
December 11, 2016, 11:27am
14
Thank you for all the info giorgoskok.
Would you know the lumen values for the different modes?
I might get a couple more while the price is good, if the spacing is to my liking.
Thanks
giorgoskok
(giorgoskok)
December 11, 2016, 2:08pm
16
I’ll give you an estimation :
Lowest - 10-25 lm
Low - 70 lm
Medium - 270 lm
High - 775 lm
mrheosuper
(mrheosuper)
December 11, 2016, 2:17pm
17
A little bit disappointed,
giorgoskok
(giorgoskok)
December 11, 2016, 2:25pm
18
OP updated with runtime for Medium mode , with AA .
Why , if i may ask ?
evankouros
(evankouros)
December 11, 2016, 2:42pm
19
Just saw your edit.
Since a 50.6mm cell fits & works, I don’t see why a 50.5mm protected XTAR 14500 wouldn’t.
Do you have any XTAR 14500s (or any other 14500 protected of about that size) to check if they fit?
giorgoskok
(giorgoskok)
December 11, 2016, 2:54pm
20
I have the same cell you mentioned (xtar 14500 protected) , and it’s actually longer (50.9mm - 51mm) and it doesn’t work .
MAD_TM26
(MAD TM26)
December 11, 2016, 3:00pm
21
Can you just remove the protective pcb to make it fit?
I have several of those in transit to my place.
giorgoskok
(giorgoskok)
December 11, 2016, 3:02pm
22
Battery’s pcb ? Yes (but not really good solution)
Trevi_lux
(Trevi_lux)
December 11, 2016, 3:11pm
23
How about clip? I have a similar light with a similar clip, and I can not insert easy, is very closed for the flashlight
Regards
