No lockout mode? I thought the light would lockout if the head is half turned?
Yes , this is phusical lockout (if light has anodized threads , as ut01 has).
Thank you for all the info giorgoskok.
Would you know the lumen values for the different modes?
I might get a couple more while the price is good, if the spacing is to my liking.
Thanks
I’ll give you an estimation :
Lowest - 10-25 lm
Low - 70 lm
Medium - 270 lm
High - 775 lm
A little bit disappointed,
OP updated with runtime for Medium mode , with AA .
Why , if i may ask ?
Just saw your edit.
Since a 50.6mm cell fits & works, I don’t see why a 50.5mm protected XTAR 14500 wouldn’t.
Do you have any XTAR 14500s (or any other 14500 protected of about that size) to check if they fit?
I have the same cell you mentioned (xtar 14500 protected) , and it’s actually longer (50.9mm - 51mm) and it doesn’t work .
Can you just remove the protective pcb to make it fit?
I have several of those in transit to my place.
Battery’s pcb ? Yes (but not really good solution)
How about clip? I have a similar light with a similar clip, and I can not insert easy, is very closed for the flashlight
Regards
Clip is really hard to insert too.
Thanks for confirm. I any case, great light for 14500 unprotected and awesome for NiMH.
Regards
Extended View :
Flashlight :
UT02 length : 84mm
Max UT02 diameter : 22mm
UT01 ?
Thanks for saying this - https://www.youtube.com/watch?v=PQHn1BFt-u0
The user manual is a complete photocopy of the Manker E11’s, just without the Manker logo.
Without trying to sound too controversial, may I ask if this torch, and the UT02, have been copied out of spite for Manker?
Btw, thanks for the review, giorgoskok. I’m now going to buy more than one.
Sorry , UT01 i meant .
So, only 0.3-0.4mm length difference makes such a damage... :(
I guess that there might be even some IMRs that won't fit then.
Anyway, I've ordered a pair of 49.5mm UR14500P and a pair of 50mm TF IMR14500, so I will have 14500s that fit, but... do you think that there might be a problem with flat-top cells? Will the UT01 work with these?
They will fit.
Most IMR without button top work ok
