i got 3 convoy s2+ nichia when it was on sale
but i want AA version not sure if this one is comparable to nichia LED
I like the looks of these little blue Jetbeams
Send me bank notes from around the world ……and I’ll send you pictures of me running away with your $$$$
Christmas is about giving
Then it is probably correct.
Your in Melbourne?
bahahaha first you need a Santa beard!
Sorry Djozz one more question how bad are these for your eyes?
30 minutes drive to your place man
What is the diameter of the lens? If it is not more than 10mm, you can get a 10mm ZWB2 filter on aliexpress and get rid of the white background light. I never found a 12mm ZWB2 filter.
You Sleigh me …
depending on intensity, but: pretty bad, do not look directly into the beam and when looking at reflections: not too long. Checking a note for a moment is fine but do not stare for minutes.
Common polycarbonate protection glasses block 365nm very effectively btw
I bought this one, and also made me an S2+ with the 3535 UV LED from LED4POWER ( I think ?) and a ZWB2 glass.
I’ll make pics when my Jetbeam shows up to show the difference.
Maybe I should have bought another UV LED from known source and put it in a BLF 348 instead of impulse buying the Jetbeam…
For who wants to try it, here is a (the only btw) Ebay source for 10mm ZWB2 filters (do not know about the Jetbeam, but it fits a BLF 348 perfectly btw):
http://www.ebay.com/itm/2pcs-ZWB2-Ultraviolet-Filter-glass-UV-filter-Diameter-10mm-thick-1mm-/262713216175?
Are there any decent AA nichia on the market approximately same price as convoy S2 uv?? if not why no manufacturer fill the gap…i’m sure few people would want!!
Not that I know of. Tank007 sells some AA UV-lights, but I think they are expensive and way behind on the leds that they use.
There is AA light with nichia 365nm but it cost much more than convoy s2
JAXMAN E3 Cree UV Ultraviolet 365nm AA E3 Cree UV Ultraviolet 365nm AA
Forgot about that one (link does not work btw), it has the good filter but the led is weaker than the Nichia 276A that Convoy uses (but can be upgraded of course )
Is it possible put forward to the man “Mr Convoy” to make/produce AA nichia version for us BLF?? how does work and why hasn’t he done it yet?? mmm?? As stated by Mr djozz and Mr Nicolicous other UV expensive and ‘…out of date’ so clearly there a hole and $$$ to be made but no one willing fill??
Does this mean if i install/glue? this filter to my BLF-348 uv will improve/enhance?
