This is getting ridiculous, over 10k lumens in the palm of your hand. We need a licence to carry these soon given the insta-flash risk to iris damage. The ministry of flashlight safety association(MFSA) will soon make an announcement regarding the application form at BLF . All current BLF members will be given an automatic exemption of course.
OW God, must resist……
That dt35, what wonderful light, 8k+ lm and about 1km of throw
MUST RESIST!
Hey freeme, have a coupon for it?
MUST RESIST! :weary:
Are wonder if these are real switches or “tactile”, the later would be a deal breaker considering Imalent history of malfunctionning “tactile” switches
Interestingly the DN35 claims 2200 ANSI lumens on turbo, could this be the first driver to really push the XHP-35 HI with 1x26650 ? that would be beyond 10A at the tail with a fresh cell.
Is there any group buy/code in the works for the DN35 ?
> Interestingly the DN35 claims 2200 ANSI lumens on turbo, could this be the first driver > to really push the XHP-35 HI with 1×26650 ?
This seems to be a typo. Cree says that the XHP35-HI gives only 1483 lm.
A 26650 should run easily in this light, doesn’t even need to be high drain.
I’m excited to see how these new models really behave!
I hope to see a GB
Cree numbers are very conservative and usually rated at where the emitter still achieves a decent lm/watts while managing the heat, with proper heat sinking the XHP35 HI can do up to 2,500lm.
Patiently waiting
This post got me excited, and I already bought 2 of G20’s using your code, you and Martin are driving me broke
Do you have Beamshots of the DT35 and DT70?
YES, BEAMSHOTS, WE NEED BEAMSHOTS!
I think the beamshots its only thing to pick that and broke my wallet until 2018 comes
Danm, I must stop to reading the threads of this forum………
MUST RESIST!
Finnish store claims that the DT70 has 4 dedomed xhp70…
16k lumens seems even more farfetched in that case
Idk why but the Imalent lights never took off on CPF. They look like great lights and I was going to buy one at one point. Still interested and the new lights look impressive indeed!
Surprising! Usually manufacturers do the opposite. In this case it’s excellent news. Do you have links where this has been published, like Texas_Ace did these last days for the LatticeBright (node 51604)?
And what about the XHP70? Can it reach 4500-5000lm?
The XHP70 can reach up to 6,000lm, even close to 7,000 if I remember correctly from one of Dale’s mods with a FET driver in a convoy L6.
Cree does not over rate their emitters because they must provide a spec sheet with full details, unlike flashlights manufacturers.
Impressive! I’d like to see those numbers.
Are there drivers for flashlights, for single LiIon cells, that can approach the necessary current? It seems boost drivers don’t.
XHP70 N2 can’t reach 6Klm even at 12A 7.75V, yes 93W for a single LED
I tested the XHP70 again last night, now mounted on a XHP70 Sinkpad, with the romantically wandering traces avoided by scratching some masking away, does not look pretty but it works alright. What is most important is that the thermal path of the middle pad has improved compared to my makeshift board using a XM-L Sinkpad and copper bits. [image] It is the exact same led as the first test and I plot the results together the makeshift board results because that is pretty interesting: at high cur…
Cree XHP70 up to 4022 Lumens and XHP50 up to 2546 lumens - Multi-die leds. - #576 by djozz
That’s an N2.
There are P2 binned XHP70’s now.
Here’s one of Dale’s posts on his L6 (7400lm). Convoy L6... XHP70 Beast! - #3192 by DB_Custom
That’s originals or dedomt XHP70 in the DT70?
Would love to try the DN70, not really impressed with the output on my Olight R50 Pro.
Any codes for it?
