I intended to test the otc-less design we discussed in the attiny firmware thread and a ramping firmware with the new red Convoy 8x7135 driver (whith actually is 105D design):
https://de.aliexpress.com/store/product/7135x3-7135x4-7135x6-7135x8-with-new-firmware/330416_32734523412.html
- but I was not able to program the mcu. I do this programming every day with different programmers and drivers, so I don’t believe it’s a fault on my side.
I assume SPI programming has been disabled when loading Biscotti into the mcu, but it might also be a faulty connection on the driver board. Since I only have 1 of this drivers currently I can’t check with others.
Has anybody been successful in re-programming this driver?
Edit:
Btw, I had the same problem with the newer batch of BLF X6 FET+1 drivers, they also weren’t programmable. Here the reason clearly was wrong fuse setting (SPI disabled), some other forum member verified this problem and was able to program the mcu with high voltage programming, which overrides disabled SPI. I guess I have to build a high voltage programmer soon.
