I would not say better then most fakes, it is just not neon blue like some fakes. The super blue/purple tints are the odd ones out for me.
I would say this one is around a ~1x tint, somewhere around 6000k if I had to guess. Way too cool for my liking but also not all that much different then most of the real Cree LED’s I get in cheap lights.
Interesting results, like I said the best I ever tried was a sliced dome and was simply not impressed. I only tried it in 2 lights though and those I didn’t try that hard.
True, most ppl count it as garbage yet i`ve found its better than most( nearly all) Hi emitters at 2.8 amps in C8, X6 or so look alike lights, 150 lumens less yet it throws better, the tint is good and i have like 60-80 of those luying arround doing nothing ( came from various flashligt used as hosts)
They cant hold high amps though
Surprisingly not really, although the tint was really not part of the test, just noting the tint of the LED for comparison purposes.
I have had real Cree’s with worse tints, I got 23 Skyray kings earlier this year and out of them only 3 had real Crees but tint wise 1 of them was no batter and if anything worse the most of the latticebright. The LB LED’s also varied a lot between lights, some had a fairly reasonable cool tint such as this LED and others had a much worse tint.
I even had one LB with a reasonably neutral tint.
Another thing I noticed is that the tint seems to improve as you drive them harder (well until they start turning blue due to heat anyways).
For the record, I am not defending the Latticebright LED’s, simply testing them and reporting the findings.
I was just referring to the drop off above 4A, that seems low compared to Djozz’ tests. Poor thermal conductivity between the die and heat pad might explain that and not be surprising from a knock off emitter.
Yeah, the thermal resistance in these is most assuredly much higher then real Cree emitters. In fact I would say that is by far the largest difference. If the thermal performance was better I bet it could match the XP-G2 that is should be competing against.
The reflow should be good, same way I do all of mine although anything i possible. If I feel like it I might run this one up till it pops and replace it with another and then test the new one.
