[SALE] High CRI 90+ Nichias (ENDED)
Can you test one to check for the “Spiegelei”-problem?
I will do that tomorrow when I have them. Don’t worry, I won’t export egg yolks to you guys. :smiley:
Package arrived today. :slight_smile:
Looking forward to the SM453 144AM.
Nice Jerommel, I hope the other packages will arrive well too.
Had time to do a quick mod with the 219C SM353 and I like it an awful lot, my new favorite led. Like the 5000K 219C that has been around for a while, it behaves well in reflector lights.
Could not find the right white balance, the light is warm-ish but not this warm.
Hi Jos,
For your reference……
Shot in 5600K white balance:
Original post: https://budgetlightforum.com/t/-/43046/15
- Clemence
That looks good clemence, but my (Xperia Z3 compact) phone camera does not let me set a colour temperature for the white balance, just a random choice of 5 standard settings, plus an ‘auto’ setting that sometimes does the right thing but more often not.
Oh wow, that does look nice. I skipped the 353 because I thought it would be too close to the 403 to be worth fooling with, so I went with the 305 instead. Maybe I was wrong. Next time…
I’m still using Xperia V. It’s an ancient phone before the Z era. Often when I don’t have my Olympus EM5 in hand I use camera FV-5 application. Much better control than the sluggish OEM camera application. Sent you the link via Whatsapp
- Clemence
I finally got around to posting up the results of my output tests with the 4000k emitters, they are basically the same as the 83cri test djozz ran before but with a bit lower output naturally. I had the test setup out and figured I might as well see what they can do.
I made up a bunch of S2’s with these LED’s for Christmas gifts and they turned out great, I am also using it in my EDC now as well. With the OP S2 Reflector it is a good beam and tint but with a TIR it is simply stunning. Something about how the TIR mixes the beam just makes things look even better. This is part of why I prefer TIR’s in most lights. If I want flood then I will pull out a mixed tint triple :sunglasses:
Nice to see the 219C R9050 sm57x/sm50x listed!
Soooo, true. I’m a fan of TIR too. Will try the 67mm Gaggione thrower optics later
Indeed =)
How’s the light bar project? I made some drawings for you earlier
Interesting!
I like TIR optics too.
but which ones to buy…???
What’s your application? What size?
I got all my Gaggiones from Supreme Components Singapore: http://supremecomponents.com/
And they’re not cheap :cry:
Another fan of TIR optics over reflectors here.
For your typical 25mm diameter tube flashlight, one my favorites is the Ledil LXP-RS
Nice throwy beam, yet smooth enough for close up work.
Goes great with the Nichias!
Where can we buy those?
Ledil LXP-RS can be bought from digikey
Made for the Cree XP series so goes great with the Nichia.
Update 161227: The NV4L144AM sm453 9050 received at my workshop. Will spiegelei test it and post the result
Inventory stock update 161228:
- 219C 9050 sm305: (0/95 pcs left)
- 219C 9050 sm353: (0/100 pcs left)
- 219C 9050 sm403: (8/300 pcs left)
- 144A 9050 sm453: (74/100 pcs left)
- 144A 9050 sm503: (90/100 pcs left)
- 144A 9050 sm573: (96/100 pcs left)
  • VirEnce 30mmx30mm CDTP board (28/50 pcs left)
It goes slow!
I was again in the hospital for 2 weeks and i am now home for a bit more than a week and i am still not fully ok. Thanks for the drawings. The Aluminium Profile (should arrive next week) will be 2000x80x60x4mm. I will use only 3*144A LED´s. The Ledil JENNY-CY optic with holder is 35*50mm. I think it will look nice when it is build in the Profile.
And i have ordered a few things more (Amazon.de). A few Potentiometer to mod the driver ,so i can set min and max brightness. The Optics are in the Shopping Cart at Mouser (still adding more things to the list like driver parts and electronics that i can not get easy in germany) but have to wait till next month with ordering.
What will be the highest bin for the 219C R9050 sm57x/sm50x (i hope still it will be 280+ :smiley: )
Hospital? I hope you won’t get back there anytime soon. Keep healthy man.
Is that a boost driver? Looks very similar to mine. I bought some from ebay for as low as USD 6/pc. Try to get as rugged as possible potentiometer, The cheap one usually wears faster and jumpy.
Just like me I prefer 5700K high CRI for workshop and my office.
As for the bin, I have no control of what I’ll get. Nichia always randomly decide the proportion. We were lucky I got that D240 sm403, seems like the majority will get D220 for the 3 steps.
Get well soon TOD,
Clemence
