Yep, sounds like operator error ‘mortuus’ if it broke as you say; when you dropped the light. It doesn’t appear “cheap” had anything to do with it if it is “broken” as you describe. “Broken” sounds like what ‘hank’ described…… “cut”.
Some days we are the windshield, other days we are the bug.
Something like THESE will usually work pretty good as long as the holes are wide enough.
I have also used a very small split ring in one of the holes on the light to attach the lanyard cord to , as they are not near as sharp as some of the lanyard holes I have seen.
NO i mean i dropped the damn flashlight because suddenly the thin wire just snapped duuuh gravity lol ? see the picture… i didnt do anything wrong… ive had cheap flashlights for so many years and i never had a lanyard break down like this, last thing i expected from an olight is that to go down… very dissapointed… see the picture the wires are really thin and m22 weighs a bit it should be alot thicker if u ask me…
Oooooh, I see now………
It broke before you dropped the light. (You dropped the light because it broke.)
Is there a sharp or rough edge on the light where the lanyard has been attached?
If so, maybe it has been slowly cutting into the lanyard over time and it finally just cut through.
I have actually had a couple of lanyards “cut” or broke , from sharp edges that are in the very side edges of the holes that ended up just like that one. If you use the little spilt ring or the clip in type lanyard , as I mentioned above , you will have metal going through the hole and the lanyard string will not get near the abrasion or cutting effect with the string type , if there are any sharp edges on the lanyard holes.
Check these lanyards from Simon (Convoy @Aliexpress). They’ve got both tail rope & key buckle and you can choose the color you prefer for a good price.
no nothing sharp what i can see… u can just say that olight dont bother making good lanyards it seems… well no big deal just suprised i will get it a better one then hehe.
Actually now that i feel the hole for the lanyard it is a bit rough and sharp really design flaw there so no wonder it broke so not sure if a normal one will work i need something thicker ?
@evankouros i will give those a try cheap to so might aswell buy a few.
The holes should be chamfered or “fillet” rounded. Often they’re not, on cheap lights; that leaves a sharp 90-degree edge that wears/cuts through string over time.
Something thicker might not fit. I think maybe you were just a bit unlucky. I expect this sort of micro-cord that lanyard strings are made from is a pretty standard thing and I, for one, have never heard of it failing under normal use. If you use it as your primary means to pull a torch out of your pocket or whatever, then there may well be a strain on it, hence your picture which seems to show some fraying. I think the more important consideration is: did the torch survive the impact??? You can buy like a dozen cheap lanyards off eBay for about £1 if you really need one.
Not only that’s true, but as far as I remember Olight gives a steel ring in the package of it’s flashlights, at least when there’s also a lanyard in the package. The thing is that most of us (me one of them) usually don’t use it.
While It’s not the solution you want, you can feed it back through and tie it.
But definitely I would smooth the hole edge first or put a key ring through the hole and attach the lanyard to that. Depending how small the hole is you may need to drill it a bit larger to fit a key ring through it. I have done this on a few lights.
Also as mentioned earlier, lanyards are cheap on ebay.
Last order I got a 10 pack and put them on everything like camera, lights, etc.
That thin string will fall under normal wear and tear and, as such, is up to the user to check and maintain. The mfr. is not likely to warranty a wear and tear item, or damages caused by failure due to lack of maintenance.
I am pretty sure no flashlight manufacturer makes their own lanyards…
That would be a huge waste of effort and money.
They probably just bulk order them from china with the brand name printed on it.
give me a break, this is a flashlights that should come with a lanyard that will not break down so easy i didnt do any over wear really it just snapped, lucky u can easy switch it but still its silly the hole is big enough for a wire alot thicker , and its strange the lanyard to my s1 baton is identical to the m22, to me it should be thicker because the light is bigger and weights more dont u agree? olight dropped the ball here sadly. Thankfully the lights dont break so easily so im happy the light can sustain falls.
Keyring is a good suggestion think i will do that, now lets wear and tear off that keyring then haha
