no nothing sharp what i can see… u can just say that olight dont bother making good lanyards it seems… well no big deal just suprised i will get it a better one then hehe.
Actually now that i feel the hole for the lanyard it is a bit rough and sharp really design flaw there so no wonder it broke so not sure if a normal one will work i need something thicker ?
@evankouros i will give those a try cheap to so might aswell buy a few.
The holes should be chamfered or “fillet” rounded. Often they’re not, on cheap lights; that leaves a sharp 90-degree edge that wears/cuts through string over time.
Something thicker might not fit. I think maybe you were just a bit unlucky. I expect this sort of micro-cord that lanyard strings are made from is a pretty standard thing and I, for one, have never heard of it failing under normal use. If you use it as your primary means to pull a torch out of your pocket or whatever, then there may well be a strain on it, hence your picture which seems to show some fraying. I think the more important consideration is: did the torch survive the impact??? You can buy like a dozen cheap lanyards off eBay for about £1 if you really need one.
Not only that’s true, but as far as I remember Olight gives a steel ring in the package of it’s flashlights, at least when there’s also a lanyard in the package. The thing is that most of us (me one of them) usually don’t use it.
While It’s not the solution you want, you can feed it back through and tie it.
But definitely I would smooth the hole edge first or put a key ring through the hole and attach the lanyard to that. Depending how small the hole is you may need to drill it a bit larger to fit a key ring through it. I have done this on a few lights.
Also as mentioned earlier, lanyards are cheap on ebay.
Last order I got a 10 pack and put them on everything like camera, lights, etc.
That thin string will fall under normal wear and tear and, as such, is up to the user to check and maintain. The mfr. is not likely to warranty a wear and tear item, or damages caused by failure due to lack of maintenance.
I am pretty sure no flashlight manufacturer makes their own lanyards…
That would be a huge waste of effort and money.
They probably just bulk order them from china with the brand name printed on it.
give me a break, this is a flashlights that should come with a lanyard that will not break down so easy i didnt do any over wear really it just snapped, lucky u can easy switch it but still its silly the hole is big enough for a wire alot thicker , and its strange the lanyard to my s1 baton is identical to the m22, to me it should be thicker because the light is bigger and weights more dont u agree? olight dropped the ball here sadly. Thankfully the lights dont break so easily so im happy the light can sustain falls.
Keyring is a good suggestion think i will do that, now lets wear and tear off that keyring then haha
It has been said already but Olight , ThruNite , Nitecore , Manker and even the all mighty Surfire (all the companies) , more than likely buy the lanyards in bulk that come with their lights and throw one in with each light packaged.
None of them make the lanyards themselves more than likely and 90 to 95% of the lights you receive , regardless of the brand of light or the size of the light , come with the standard lanyard like you received with your Olight M22.
I have around 85 lights now in many different brands and only 4 or 5 of them have came with a heavier lanyard , no matter how large or how small the light itself is or the brand of light it is. Those that are heavier (nicer) lanyards , have the clip on the end. The thing with those is that they wear off the anodizing , so if that type of lanyard with a clip is supplied , then many people would be upset that their $200.00 light is getting scratched or having anodizing worn off from the metal to metal contact where it attaches.
It is really a NO win situation for any of the companies , as there will be probably be complaints no matter what they supply because everyone has their personal preferences.
I personally don’t use many lanyards , but the ones I do have attached to just a few of my lights are attached in one of 3 ways………
1. I cut the little string completely off (like the one you have that broke) and run the heavy part of the lanyard itself through a split ring and attach it to the light.
2. I use the metal clip style lanyard , if the hole on the light is big enough to accommodate it , and attach that directly in the hole.
3. I use a split ring in the lanyard hole of the light and attach the metal clip style lanyard to that.
The pictures below show the 3 ends or attachment methods I would use , with the first picture using a lanyard like the one you have that “broke”. I really don’t see any of them breaking or wearing through , nearly as easy as the little string , even with the biggest of handheld lights out there , when attached in one of these ways.
Get you some 1.5 or 2 mm DYNEEMA and call it a day.
Just don’t wrap it around your wrist if there is a chance it or your light might get hung up on an object large enough to drag you. Cause it will rip your hand off before it will break.
Marlow D12 Max 78 at 3mm is a black cord with a 3300 lb breaking load! Yes, a 1/8” cord with a ton and half capability! Rip your hand off, yup! Got some coming, now I have to learn to splice cord. lol
This sailing supply site likes the high end shipping options. I started not to buy because of that then realized even at some $2.00 a foot final cost it’d be some really cheap lanyards that would hold up exceptionally well. We’ll see how that plays out. I bought 20’ of this one. A 10mm cord could be used to tow a car for pete’s sake! (over 20,000 lb bursting strength on the D12 with SK75 Dyneema. Astonishing! Higher grades are much stronger of course.)
You can probably pick up some “splicing tips” on the Samson site too.
Check out the video Why Splice first off.
And yeah, this is not something you would want tightly wrapped around your wrist in the form of a lanyard or use as a necklace unless it had a breakaway release. Otherwise you would be an injured or dead duck in a ‘hangup situation’.
Of course that probably applies to other products as well.
