I got a new code from BG but when I went to test it I found that now the link to the cells is dead. :person_facepalming: I’m gettign the dreaded “404 - Page not found” error. Give me a bit to work this out. I already sent their rep another message. They’ve been pretty good about response time so I imagine it should all be worked out within a day or so. Once I have it all confirmed I’ll post the new code and a new link if necessary. The code is for 50% off this time so it should be well worth the wait.
All fixed.
We have a new link and a way better discount!
Here is the new link: KP5200 Protected 26650
Here is the new code for 50% off:
KP50OFF
This brings the price down to just over $7 each US. :+1:
This has also been added to the OP.
The L6 was literally developed with these exact cells as the intended power source. It will like them. :+1:
At this price you’re getting two cells for the price of one. A few people held off on buying the L6 when it came out because you had to buy $30 worth of cells to power it. Obviously, prices have improved and this deal BG hooked us up with is the best I’ve seen yet.
I removed the 50% off info from the OP as that deal is dead.
I recently found out the coupon code was only good for 50 uses and we blew through them pretty quickly.
We still have a pretty good price though with the previous code.
Here is the link for the new KeepPower protected cells: KP5200 Protected 26650
Discount code: Keeppower
Note: The discount code above drops the per cell price to $10.99
If I could fix that I would…
Maybe someone in or around Singapore can chime in with a recommendation? Shipping restrictions for Lithium cells are getting tougher on a regular basis.
