tons of them available online, for regular size cells you can get holders at radio shack, however those holders come either with wires, or snap in, (9v) type connector, or simply solder connection, i’m not sure about b6 but mine x4 came with wire that had banana plug on one side, (to plug into the charger) and alligator clips on the other, so you can clip it to pretty much anything.
lipo packs already come with balance tail\wires attached, so you wont need any extra wires.
there is mh-c9000 analyzing 4 bay charger, but it does not work with packs nor with li ion cells, nicd\nimh only. i’m not aware of any other 4bay analyzing charger that works with packs and li ion cells, maybe someone else knows about such charger
The opus and liitokala both seem to have shortcomings and they are not able to charge to 4.3V. I have been looking into the MC3000 and it does most of the things I need it to do but I do not like the sound of “tinkering with flattop cells” as most of my cells are flattop. And
Are these issues fixed with the upgrades? I mean your test was done in 2015 so the should be fixed by now no?
Which hobby charger would you recommend, I need a reliable one if I’m gonna charge my 18V packs and lead acid batteries with it as these things are really expensive. I’m talking about at least $75 for an18V pack and my lead acid batteries are way more than that.
Pfff the more I look intoit the more desperate and confused I get. No such thing as a perfect charger I guess.
Yes and it has a few extra functions compared to the software I tested.
But you still need to mount some flattop batteries a bit high. I mostly uses GA cells and they do not have any connection problems.
I will not recommend any hobby charges, I do have a few but do not use them much. If you need information from people that uses hobby chargers, try a RC forum.
I use magnets or 18650 holders. bought them on 11/11 at AE for a few pennies. electronics are my hobby so I had them anyway/can use more of these holders. I also build my own lithium battery packs for other devices like development boards.
edit: the main reason why I bought the imax is I can set a higher charge rate. have plenty of dedicated LiIon chargers and the max they do is 1A for 2 bays. also needed something that works at home, in my car, anywhere really.
you can charge 18v pack with hobby charger, as well as lead acid, i charged my 18v dewalt battery few times with x4, no issues, same with small sla from emergency lights. if you plan to charge car battery, it can do that too, but it’ll take few days or a week even, if battery is big.
I use a DPS5015 and a iSDT sc608, you don’t need the DPS but it does add flexibility. I did a video here playing around with the units but only watch if your considering as tbh it’s a bit long and boring otherwise. Link: YouTube sc-608 at the end I get round to doing a large SLA on the unit.
I also have a few battery holders on route and a dc load, much better than the discharge avalible from most hobby chargers that take forever and discharge nowhere near the rate modern LEDs consume power.
It all takes a lot of parts, effort and time but ultimately you do end up with a far greater range of options.
Can someone who owns a imax b6 comment the link i posted? Seems like everyone here likes em yet on the rc forum they say it s cheap knock off with a lot of errors and inaccurate readings. Am I missing something?
I initially bought the clone and it worked fine. A friend has the authentic item (for RC) and it feels the same. I don’t have any software issues with my clone and it works fine with lithium cells.
Apparently there are issues with NiMH cells in series (that would be the setup for them to charge/discharge) but I frankly have such a variance in my NiMH cells (age, brand, price are all different) and I don’t have a strong need for charging these products.
My clone was sold as “real” but I realized b/c of price and seller it is a clone before I bought it. you can change the firmware on select models.
I have to recommend the ISDT SC608.
It’s far superior to the outdated B6 and family.
It has a cortex M4 processor, bright full color IPS screen, and a simple, fast, high quality button.
It can charge at up to 8A or 150W, several times more than the B6, whereas the B6 will not even be able to parallel charge 6 batts at 1A each. The ISDT has options for HV lithiums without flashing anything and it’s easy to update firmware. It also has higher precision voltage measurements and takes individual IR estimates with the balance tab connected. It has a much wider input voltage range as well.
The best part is that it’s tiny and fits in the palm of your hand but still dissipates the same amount of power as the B6, except that it has thermal monitoring.
Can be found for 40 shipped from a US supplier. This new charger far outclasses the antique B6 that we used to use like 10 years ago.
I have a clone B6 that I got for $20 shipped and have been using for years, and it’s acceptable but the ISDT is nicer to use. The B6 has a crappy blue calculator screen, the buttons are finicky, and voltage measurements are not as accurate. It also charges much slower. I don’t like to wait so I charge my 18650s at 2C, which wouldn’t be possible with the B6.
I still use my B6 but I can hardly recommend any electronics that were designed over 10 years ago and hasn’t really been updated since. I know it’s cheaper though.
For refresh cycling large solar batteries you need a way bigger charger
Just imagine refreshing a 120Ah 12V battery with 15W max discharge of those hobby chargers
Most do it with a charger that can supply at least 0.2C for your biggest battery
and then connecting the battery to a 1500W inverter powering a cheap heater
@ lexel: I taught also, gonna look for a decent charger just for lead acid batteries or just keep borowing my the one from my friend. hello: really? I saw a post here somwhere bout a charger like that and that scrolling wheel just looks like it won't last long. Just the way it's build makes me think it's crap but I never had one in my hands so... milspec: ok they’re talking bout clones and not the skyrc one that explains alot thx.
I don’t know about the liitokala, but the Opus will definitely charge to 4.35v. I cut a circle hole in the bottom of my Opus so I didn’t have to remove the cover every time I wanted to switch it from 4.2v to 4.35
like i said before, there are lots of fake b6s around, some are ok some are total garbage. b6 is a good charger for the price, (the real one at least).
i’ve never used SC-608, it seems to be good, on paper, and at least 1 member here seem to be happy with one, if you can find that one that fits your budget go for it. just make sure it is real, as soon as something gets popular and demand grows, fakes flood the market.
If you are able/willing to spend 40$ or around that budget I’d not recommend the imax B6. The clones are cheap (I believe I paid 9$US plus shipping for mine) but at a higher range there are significantly better balance chargers!
One recommendation is in this thread and the RC groups will give you a good overview, reviews and rankings.
About the scroll wheel, yes it’s a high quality encoder.
Everything about the build is solid quality, even the IPS is quite nice and all functions are color coded, as well as charge complete screen.
All luxuries but nice to use.
you can still charge them to 4,2v it will not cause any harm to them, actually it would be even better as far as lifespan, but you will lose about 100-200mah in capacity by not charging them to 100%
I use a Imax B6 for most of my charging needs with a 14X parallel cell holder with built in volt meter for quick voltage testing of cells, just toss it in for a second to get a reading.
It works great and I could not be happier. I do have a cheap nitecore single cell charger for times when I just have a single cell to charge (rare).
