ThorFire Lightning Deals- $12.79 for 500 Lumen ThorFire TG06S mini flashlight Updated 21th April 2019
Hmm, me thinks I spy a Texas Avenger driver in there lol. Same plan I have for mine.
This VG10 clone was a real winner: https://www.amazon.com/gp/product/B01A6DK9YM/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
Sooo much nicer than the real VG10, was only available for $12.99 Prime for a short time. I bought mine back on Dec 11th. The knurling makes it a much better feel light, anodizing more a flat black, and overall quality just as good. Sorry I got only one.
Amazon Lightning Deals Coming: ThorFire TG06 tactical flashlight 25% off!!
Deal Price: ONLY $11.99!!
Timeline: 3:25 AM PST-9:25 AM PST, 13 Jan 2017
Now or Never, Grab yours tightly here: amzn.to/2jCwliL
Lol…ThorFire…you guys are killing me this month :person_facepalming: I guess I’ll be getting a few of those too.
Good deal! If this came in a neutral/warm tint, I’d grab one.
Haha…Believe that you will get more than a flashlight,like satisfaction, happiness. :smiley:
#LightningDeals: ThorFire PF01S #penlight
Discount: 25% off
Deal Price:$11.99
Timeline: 2:50AM-8:50AM PST, 14 Jan 2017
Grasp it here: amzn.to/2j6VeCt
We also have ThorFire TG06 #Flashlight on Lightning Deals at 3:25AM-9:25AM PST 13 Jan. For more details, please check our last post above. Don’t miss it!!
I can’t get the thread to work. I can’t get Amazon to accept the coupon code 9F3PMESJ either. Please help
Which flashlight would you like to buy?
The VG10
Please use this code to buy VG10: SQYPGBB4
Nice, thanks for the heads-up.
Which one is the official seller
“Thorfire Direct” or “Thorfire & More” ?
Our official website is www.thorfiredirect.com
Hi BLF guys,
Lightning Deals again: ThorFire camping lantern
Discount: 64% off!!(No code needed)
Grasp here: http://amzn.to/2iDwSAQ
So “Thorfire & More” is not an official seller?
https://www.amazon.com/sp?\_encoding=UTF8&asin=&isAmazonFulfilled=1&isCBA=&marketplaceID=ATVPDKIKX0DER&orderID=&seller=A2R9O9RPRP4XXU&tab=&vasStoreID=
My thorfire VG10 came in, I grabbed one because the price was too good to pass up and didn’t expect the quality to be nearly this good. This is one nice light!
I have always loved the P60 form factor for the general usefulness of the beam and size of the light and this is a much improved version IMO.
Are these glued? I tried briefly to open it up but it would not budge. I sure hope it is not since the only real complaint I have are the cool white LED that I want to swap out for a 219C or XP-L2 (along with more output naturally).
Is there still an active code for the VG10? I tried the one posted a few posts up but it said it could not be applied. I now want at least 2 more of these (IF they are not glued and can be opened), I think a quad LED could do well in one of them and the other with a 80 CRI XP-L2 @ ~1800 lumens should be nice.
I have to say, after seeing this light I now want to try out a thorfire C8. Any codes for the C8 right now?
The one I ordered wasn’t glued. I ordered 3 more the day I got this one after how nice the beam was from a XP-L HI…very solid light.
I just got it open, it just took the right tools. :confounded:
Pressing the bezel against a “jar opener pad” got it open fairly easy, although don’t try to grip the bezel with it, that did about as much good as using my fingers lol.
The driver ring was a bit harder, it bent my tweezers that can usually do this but then I got out the big guns, my lock ring pliers from the shop. That got it open.
After looking inside, I am even more impressed, very well built, machines and put together. The glass even has an ar coating.
The only issue I saw was that the main bezel o-ring was broken on mine after removing the bezel, not sure if this happened when it was put together or when I removed it though, a little lube on the o-ring before install should fix that and luckily they sent spare o-rings with the light.
The LED also does not have any thermal paste but unlike some I am not too worried about this. Naturally I would love to see a DTP star and thermal paste but to be honest at the drive currents these work at stock no paste is just fine.
I like the mode spacing on the stock driver. I am going to run it through it paces in a little while and see what it is doing. I also see an easily accsessed sense resistor, I think I might try bumping that up a bit to see what happens.
Sadly I am out of 20mm Stars so I either will have to use a 16mm or wait till Simon re-opens to order more before I can mod it.
Makes me look forward to the TG06 I have incoming
Did some driver tests. I expected it to to be a buck driver but it acts like an FET driver. There is no regulation in any mode but on the plus side I am getting 14W worth of power (about 3.3A at the tailcap) in stock form. Although the output drops with voltage like an FET.
Not sure if my driver is messed up or if it is meant to be that way? I would have preferred a regulated driver with the same output but I can accept the FET.
It still works fine and is putting out over 1100 lumens bone stock on a 30Q 18650! It also has a true moon mode as well. Overall I think this is the best bang for the buck light I have in stock form. All it needs is a neutral white emitter (or better yet a 219C 90+ CRI and/or 90+ CRI XP-L2) with DTP copper star and it would be perfect.
Oh, and they sent a spare tailswitch with the light, it would be REALLY cool if the spare switch was a reverse clicky so that you have the option.
