A cylindrical heating cartridge pressed into a hole in a small block of aluminum would work. I used the ceramic heating cartridge from an old 100watt soldering iron. I drilled a half inch hole into the side of a 3” diameter by 2” thick piece of aluminum. I also have a temperature controller but haven’t used that part yet.
If I were to do it again I would use 3” by 1” and a 200watt heater cartridge. As it is now it takes about 20mins to heat up and 1.5 hours to cool if not heatsinked or cooled with a pan or something else to pull away the heat.
I’m sure it will.
The block shouldn’t be large though, or ti will take ages to heat, of it will radiate and air-cool too much.
When you have a good heat conduction between soldering iron and the alu block, it will just heat it up until the thermostat ends it.
Usually those soldering stations are around 60 Watts, so i see no problem.
It may take a while to reach that 200°C though. (depending on size of alu block and ambient temp. and airflow, etc…)
Had to look up the post from three years ago… this is what I made back then. My reflow skills have improved a lot since then but I still use the exact same contraption, it works well;
When I was a kid, my parents had an automotive vinyl seat repair kit that included a soldering iron type of tool with a flat paddle tip like pictured below. I’m curious if one of those would work for reflow.
could a copper bar be used instead of aluminium? Heat up the bar with a gasburner with the star on it. Or would the heat release unhealthy gasses from the copper?
A hot air station is great if you plan on reflowing tiny components on pcb's. If not, get one of these. Often on sale for about $8. Just put your star, solder paste, and led in a helping hand. The heat from below and with in seconds, it is reflowed. Very easy to control the level of heat by the distance you hold the gun from the base. Plus you can remove the heat instantly with a flick of your hand. Less stress on the LED/base and no disturbing the LED as the solder cools. You'll never reflow by another method again.
ImA4Wheeler, I already have one of those in my garage! It has two heat settings: 1. Hot as Frick, and 2. Auto-ignition of anything within 12 inches. Lol.
I had not even considered using it as hot air for reflow, but I’ll certainly give it a shot now that mention it.
This looks like a very good option. I have just now started to reflow leds (melted the dome of one in the process) and was using the tip of the (obviously too hot) soldering iron under the MCPCB to heat it up. As this is far from perfect I am looking for another solution.
I’ve always used my heat gun, it works great. I do a tail-stand with it. Then I hold the PCB with a pair of needle-nose pliers over it at about a 2.5” distance. It works fast too.
This is what I use, less than 1 minute and it is done. I also use it to warm bullet moulds and melt pewter when I do not fire up the 100 pound lead pot.
I just Googled that, I like it. Basically the same as the soldering iron in the Al block, but without the handle and such - looks like the most compact option for the workbench/toolbox so far.
I’m glad I asked this question, lots of good options I had not considered!
