TA, I’m in California.
Please put me down for:
5 x NVSL219B-V1 SW45K
5 x NVSL219CT SM403 [4000K 3 steps MacAdams]
Thank you!
Thank you!
If still available
3 x NVSL219CT 4000k from chouster, bubble wrap
thanks!
I wish …
1. NVSL219B-V1— 4500K *6
6. NVSW219CT— 5000K *6
10. NVSL319ATE— 5000K *1
Thanks
The 319A just arrived.
Added with complete specs.
OP updated, please check post#1
Sorry Steel, the 319A comes only in sm305, sm505, and sm655. I posted wrong CCT
Hi,
Does that mean i can add 2 more 219B V1 to my order, or do i have to wait for the next batch?
wow, D440 ! I have not done the calculation but that sounds like XP-L territory
I have interest in 3000K and 4500K 319A but need more info
Edit: I guess 5000K
For the sake of our BLF friends, you can wait for the next batch. I didn’t have the money to buy more than 200 pcs 219B 9080. Next time I’ll try to stock more of it
Don’t forget,it’s binned at 1050mA. Will test them tonight
I’ll take 3 9080 4500k please !
Building a triple.
Needs to be shipped to USA .
If this is all ok.
Thanks!.
steel_1024:I wish …
10. NVSL319ATE— 4500K *1Thanks
Has been changed to “10. NVSL319ATE— 5000K *1”
Whats the difference in Voltage?
I can not see it in datasheet or elsewhere?
Is this the forward voltage at 700mA?
Whats the Voltage at 2,4A?
Whats the Voltage at 2,4A? Texas_Ace:
Nichia has voltage, flux, and CCT binning.
It’s in the datasheet, check again
clemence: steel_1024:I wish …
Steel, just checked the shipping rate from ID to TW. Up to 250 Gr. it’s USD 18.
International shipping from Indonesia is VERY expensive, hence this group buy thread.
I suggest you find more buyers to split the shipping cost. With 250gr price breaks, you can order about 300 pcs LED with the same shipping cost.
- Clemence
Update 170124, 17:56 GMT +8:
Pictures and beamshots added!
R9080 is quite the novelty. I’d have gone for a bunch, but the tint chart has me concerned they’ll be unpleasantly rosy and I don’t want to be greedy when there’s a limited supply.
I’m really curious about how the 319A will do driven hard. It fits under Carclo triple optics, so it could potentially be a great option for high-performance triples.
319A can physically fits all optics designed for 219C. Check my OP for side view comparison pics. Beam shapes is another story though….
Not yet tested
djozz:wow, D440 ! I have not done the calculation but that sounds like XP-L territory
I’m not sure how that influences the bin nr exactly, apart from that comparison is not one to one, but I will wait for your test
I’ll take please:
6 x NVSL219CT SM403 [4000K]
Thanks a lot!
clemence: djozz:wow, D440 ! I have not done the calculation but that sounds like XP-L territory
That means if it’s tested at 700mA like 219C the output is comparable to D320. I checked the datasheet.
I will only do the beamshot test with whatever optics I have in hand. You do the usual Djozz STD (killing) test.
- Clemence
