[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
I have interest in 3000K and 4500K 319A but need more info
Edit: I guess 5000K
For the sake of our BLF friends, you can wait for the next batch. I didn’t have the money to buy more than 200 pcs 219B 9080. Next time I’ll try to stock more of it
Don’t forget,it’s binned at 1050mA. Will test them tonight
I’ll take 3 9080 4500k please !
Building a triple.
Needs to be shipped to USA .
If this is all ok.
Thanks!.
Has been changed to “10. NVSL319ATE— 5000K *1”
Whats the difference in Voltage?
I can not see it in datasheet or elsewhere?
Is this the forward voltage at 700mA?
Whats the Voltage at 2,4A?
Nichia has voltage, flux, and CCT binning.
It’s in the datasheet, check again
Steel, just checked the shipping rate from ID to TW. Up to 250 Gr. it’s USD 18.
International shipping from Indonesia is VERY expensive, hence this group buy thread.
I suggest you find more buyers to split the shipping cost. With 250gr price breaks, you can order about 300 pcs LED with the same shipping cost.
- Clemence
Update 170124, 17:56 GMT +8:
Pictures and beamshots added!
319A can physically fits all optics designed for 219C. Check my OP for side view comparison pics. Beam shapes is another story though….
Not yet tested
I’m not sure how that influences the bin nr exactly, apart from that comparison is not one to one, but I will wait for your test :slight_smile:
I’ll take please:
6 x NVSL219CT SM403 [4000K]
Thanks a lot!
That means if it’s tested at 700mA like 219C the output is comparable to D320. I checked the datasheet.
I will only do the beamshot test with whatever optics I have in hand. You do the usual Djozz STD (killing) test.
- Clemence
Clemence, again going above and beyond with those beamshots!
Very helpful in getting a perspective on these tints.
The 219B V1 9080 looking good amongst the rest.
Pics of the labels and 319A comparison are also much appreciated. :+1:
@chouster
shipping option #3 please
My boss really hate me today….
Came late, unfocus, and went home earlier. :smiley:
I see, thanks for clarifying.
That implies that 319 performance may be similar to 219, but who knows what happens at high currents, it may be more robust or maintains output better because of the slightly bigger die. At least then I count on beautiful beam profiles! :slight_smile:
Sorry about that, what all are you wanting? I see I have you down for the 2700k 219c, I might have put your name in the wrong LED by mistake.
Everyone please check your orders after I update the lists to make sure I have them right.
I put you down for 5 but if we do not have enough whoever is at the bottom of the list will sadly have to wait until next time.
Added
Done
Got it
I am pretty sure the 219B are sold out but I put you down anyways. When the offical inventory count is done those at the bottom of the list will sadly have to wait until next time, I added you for the 219C though.
Everyone please double check your orders after I update the lists, I am busy in the “real world” and don’t have a lot of time to keep up with this thread.
If you spot a mistake please let me know.
@chouster
If available:
3x NVWL219CT SM573
2x NVSL319ATE SM505
2x NVSW319ATE SM655
Thanks!
