So, the UT01 turned out to be a great little light.
I was late, and after reading the reviews it seems the worst case scenario upon receiving one would be having to remove rubber boot switch cover and possibly re-center the switch button. Small price to pay for such a fantastic little torch. That is, if you were unlucky enough to have received one that needed a tweak.
All in all, everyone seems to be satisfied with it. Good deal :+1:
Flash Sale at GearBest for next 5 days $19.99 US. Remember to select 1A or 3D tints.*
It still has the double tail spring, so it’s fine.
Can’t test flattops though, i have solder blobbed my 14500s, but i think it’ll work.
(have some WindyFire high drain 14500 flattops coming, will test and report).
Ive been using efest purple IMR (unprotected, flat top) and eneloops in mine since the late december group buy… no problems. Great EDC light. Outside of minor cosmetic differences its identical to Manker E11. Go with whichever is cheaper.
No it doesn’t do that.
At 3V output drops abruptly to low mode to signal the user. I am not sure what happens if you leave it ON extended when it is in that low warning mode.
When using NiMH the light shuts off completey at 1V.
I am not sure if e-switch parasitic drain continues in either of the above scenarios. Its best to assume it DOES and you need to remove the cell or unscrew the tailcap a bit.
Mac Doo in the Netherlands? I had a big mac attack while walking down the Champs-Élysées in Paris. It was like 8 bucks just for the burger, and they have no ice for the drinks…lol
Probably a silly question, but did you go into the hidden modes and bump up the high level? I can’t measure output, but I do know my UT01’s highest default level out of the box was set one step below the highest level in the hidden modes.
Got my UT01 programmed to my liking. Pretty advanced stuff for a $16.99 torch. Really liking this little guy. Seems a little closer to the 800lm rating now.
Yeah, i found the hidden modes stuff and it’s a little brighter in high now and a little lower in low (i think).
Light has programmable output levels for every mode . Here is a how-to :
1) Turn on the flashlight , navigate on the highest mode , and turn off the light
2) Press the button until it blinks two times (it will turn on in highest mode , and flash 2 times after 7-8 seconds)
3) After it blinks twice , release the switch and double click again (It will enter strobe , beacon etc and a constant current output level & regular modes )
4) Now navigate with single (short) click to the lowest mode
5) It will ramp through 3 different output levels . Single click confirms selected output level of mode and goes to the next one
6) Do the same for all the modes , and when you are in strobe turn off the light with a “long” click .
