Discussion : - Utorch UT01
206 posts / 0 new
jycheang
Hi,
Saw one Utorch UT01 at gearbest.
Anyone test on this flashlight?
Or this just another clone/rebrand E11
Edited by: jycheang on 11/21/2016 - 04:55
Mankerlight
Mankerlight's picture
Last seen: 8 hours 10 min ago
copy
Mail:sales@mankerlight.com
Web: www.mankerlight.com
Welcome to join Mankerlight Group in Facebook.
JockRobbins
JockRobbins's picture
Last seen: 3 years 3 months ago
Location: The slightly cooler end of a high powered torch
Mankerlight wrote:
copy
And a really crap cheap looking copy.
The real deal looks much better in all respects
freeme
freeme's picture
Last seen: 8 hours 17 min ago
No silly logos and lousy clip for Utorch UT01. tongue-out I am keen to test it.
@jycheang, you should know the answer by now. Time to update the title?
jycheang
Yup.
Edited
hIKARInoob
hIKARInoob's picture
Last seen: 13 hours 48 min ago
There is also a copy of the U21… I definitely prefer the original Manker lights over these clones. But to each his own Wink
Streamer
Streamer's picture
So, the UT01 turned out to be a great little light.
I was late, and after reading the reviews it seems the worst case scenario upon receiving one would be having to remove rubber boot switch cover and possibly re-center the switch button. Small price to pay for such a fantastic little torch. That is, if you were unlucky enough to have received one that needed a tweak.
All in all, everyone seems to be satisfied with it. Good deal Thumbs Up
  • Flash Sale at GearBest for next 5 days $19.99 US. Remember to select 1A or 3D tints.*
http://www.gearbest.com/led-flashlights/pp_555778.html?wid=21
Jerommel
Jerommel's picture
Last seen: 1 month 5 days ago
Yeah it’s nice, but not 800 Lumens.
And protected 14500 doesn’t fit, which is just silly, but i solved that:
http://budgetlightforum.com/node/52332
(fwiw)
Dirt
Last seen: 3 hours 29 min ago
Yep, mine seemed weaker than 800lm, but I like it a lot. Good jobs manker!
Streamer
Streamer's picture
Jerommel wrote:
Yeah it’s nice, but not 800 Lumens. And protected 14500 doesn’t fit, which is just silly, but i solved that: http://budgetlightforum.com/node/52332 (fwiw)
So now, does it work reliably with shorter flat top batteries also?
Jerommel
Jerommel's picture
It still has the double tail spring, so it’s fine.
Can’t test flattops though, i have solder blobbed my 14500s, but i think it’ll work.
(have some WindyFire high drain 14500 flattops coming, will test and report).
Dirt
I’m using effest 14500 unprotected in my ut01. No issues….yet.
kramer5150
kramer5150's picture
Last seen: 2 months 5 days ago
Ive been using efest purple IMR (unprotected, flat top) and eneloops in mine since the late december group buy… no problems. Great EDC light. Outside of minor cosmetic differences its identical to Manker E11. Go with whichever is cheaper.
Jerommel
Jerommel's picture
But what if the unprotected cell runs low?
Will the boost drive kick in, and drain it to death?
kramer5150
Jerommel wrote:
But what if the unprotected cell runs low? Will the boost drive kick in, and drain it to death?
No it doesn’t do that.
At 3V output drops abruptly to low mode to signal the user. I am not sure what happens if you leave it ON extended when it is in that low warning mode.
When using NiMH the light shuts off completey at 1V.
I am not sure if e-switch parasitic drain continues in either of the above scenarios. Its best to assume it DOES and you need to remove the cell or unscrew the tailcap a bit.
Nicolicous
Nicolicous's picture
Last seen: 7 min 53 sec ago
Mankerlight wrote:
copy
No way but it have Manker logos on the driver and tail switch plate
Nico -.-
Muto
Last seen: 23 min 38 sec ago
If it does, worst case then replace the battery, at $4 it’s less than a fast food meal.
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Big Sky Country
RobertB
RobertB's picture
Last seen: 2 weeks 4 days ago
Mac Doo in the Netherlands? I had a big mac attack while walking down the Champs-Élysées in Paris. It was like 8 bucks just for the burger, and they have no ice for the drinks..lol
cdjaney
cdjaney's picture
(fwiw)
Probably a silly question, but did you go into the hidden modes and bump up the high level? I can’t measure output, but I do know my UT01’s highest default level out of the box was set one step below the highest level in the hidden modes.
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
Jerommel
Jerommel's picture
(fwiw)
No i didn’t.
Actually i didn’t know about hidden modes..
The manual doesn’t mention it either.
Jerommel
Jerommel's picture
They’re everywhere…
I prefer Burger King though. Smile
Dirt
Got my UT01 programmed to my liking. Pretty advanced stuff for a $16.99 torch. Really liking this little guy. Seems a little closer to the 800lm rating now.
Jerommel
Jerommel's picture
Yeah, i found the hidden modes stuff and it’s a little brighter in high now and a little lower in low (i think).
Light has programmable output levels for every mode . Here is a how-to :
1) Turn on the flashlight , navigate on the highest mode , and turn off the light
2) Press the button until it blinks two times (it will turn on in highest mode , and flash 2 times after 7-8 seconds)
3) After it blinks twice , release the switch and double click again (It will enter strobe , beacon etc and a constant current output level & regular modes )
4) Now navigate with single (short) click to the lowest mode
5) It will ramp through 3 different output levels . Single click confirms selected output level of mode and goes to the next one
6) Do the same for all the modes , and when you are in strobe turn off the light with a “long” click .
kramer5150
All you need to do to enter programming mode is double tap from either ON or OFF.
It will start strobing.
Single tap to get you past the disco, SOS, beacon, turbo and blinky modes… and eventually after a few taps total you will end up in what looks like the low-firefly mode. This is really the program mode. Leave it there for a few seconds and it will start cycling through the settings for each bank:
Firefly – L/M/H (single tap to chose your output level)
LOW – L/M/H (single tap to chose your output level)
MED – L/M/H (single tap to chose your output level)
HI – L/M/H (single tap to chose your output level)
Once you finish selecting your HI, it will strobe once more. double tap to exit and you are all set.
There is also a hidden battery charge status indicator mode in there too. Its after disco, SOS, beacon, TURBO... It will flash 4, 3, 2, or 1 time to indicate battery charge level. Really cool feature that I wish they made more readily accessible.
MANKERLIGHT You have been on an anti-Utorch rant since day-1. Instead of ranting about it on a user forum, take control of your business and address the root cause. whining and complaining about your situation only makes you look bad, when you have the choice to fix it.
PUT THE HAMMER DOWN ON YOUR SUPPLIER TO NOT SELL YOUR DESIGNS TO UTORCH OR ANYONE ELSE. Or partner with a new OEM supplier who respects that request, located in a country that has a legal system in place to defend design ownership rights.
IF YOU WANT TO MAKE THE E11 STAND OUT FROM THE UT01…RE-FLASH YOUR FIRMWARE TO MAKE THE BATTERY STATUS COME FIRST IN THE BOLD SEQUENCE ABOVE. SO THAT WAY ALL THE USER HAS TO DO IS DOUBLE TAP TO ENTER BATTERY STATUS MODE, AND DOUBLE TAP TO EXIT BACK OUT. IMHO this would be much more useful than disco modes.
Jerommel
Jerommel's picture
Got my WindyFire 14500 flattops in today, and they work without any problem too. Thumbs Up
Streamer
Streamer's picture
That’s great Jerommel Thumbs Up
Your mod is quiet worthy also !
giorgoskok
giorgoskok's picture
Last seen: 2 months 2 days ago
After the stepdown at 3V (that switches to the lowest mode) , i think it has another step , that the light turns off completely (i think this is at 2.8V ? i can’t remember)
Freedom
Freedom's picture
Last seen: 11 months 2 weeks ago
Does the above apply to all battery chemistries(?) as I was under the impression that unprotected cells were afforded a different (the least) LVP.
Domari Nolo “I Refuse to be Subjugated” (1st Pennsylvania Regiment Flag) https://www.1stcontinentalregiment.org/blank
(Flagguys.com):..and man o man did they ever refuse to be subjugated. These guys were everywhere. They were important in Washington’s siege of Boston. They stayed behind and were the last to leave after covering the main army’s dangerous nick of time retreat from Long Island. They crossed the Delaware with Washington. They were “..at Brandywine, Germantown, Monmouth, and every major skirmish, and battle all the way to Yorktown..” where they fought “the most important part of the siege” according to General Steuben. These guys saw action in every one of the original 13 colonies.
giorgoskok
I was talking for 3.7V li-ion batteries . Both protected and unprotected batteries will act the same in the light (LVP wise speaking) , protected batteries protection usually kicks in @ 2.5V .
Enelooper
Enelooper's picture
When using an eneloop charged to 1.405V, my UT01 works great. When the voltage drops to 1.295V, the light starts to act weird. Sometimes it will turn on normally, sometimes I have to click two or more times to turn it on, other times it doesn’t turn on at all. Once it turns on, it works normally.
Anyone knows what’s going on?
Enelooper
Enelooper's picture
Put another eneloop in. Ran it on high until it dimmed. Now it won’t get any brighter than medium. Turned off and it won’t turn back on again. Voltage is 1.1V. Is LVP kicking in? Shouldn’t it do that at 1.0V?
