This is exactly my experience. I bought 8 of the Genix AA batteries for use in my Nikon Speedlights. Sets of four went in at a time. Within half a year of moderate use, weekends, 5 of them had gone stone dead. I chucked the rest and went back to old reliable NiMH. When they were working, they really kept the flash cycle time short. But the early death and high failure rate makes them a complete non-starter in precisely those applications where their characteristics would be advantageous.
Wilkey
They’re not ideal in some applications. Yours probably being one of them. The loaded voltage in your application may have constantly dipped well into the danger zone for NiZn’s.
I think you have to consider the application. I don’t personally think NiZn’s are suitable for high drain applications….meaning greater than about maybe 500mA
They are also apparently very susceptible to overcharge and undercharge. Most folks recommend charging to 1.9v. I don’t. I only charge mine to 1.8v
On the opposite end, I use them exclusively in devices that have a voltage cut off point at or above 1.2v (or at least a low voltage warning).
NiZn’s seem to be ruined if they go much below that so I never risk it. So far they are working great in my low drain devices that have a built in voltage cut off.
That said, it’s early in the game for my NiZn’s. I did read where someone here has been using them for over a year and they’re still going strong with quite a few cycles on them. I think your camera might be too high drain for them.
I think they are niche batteries that fit a very narrow application scope……low to very low drain, requiring 1.5v but tolerant of up to 1.8v and protected from draining below ~1.2v
I use them in my alarm remotes and they are right at 3 weeks now and still showing full power on the remote’s meter. I checked the votage yesterday and they were at 1.60v so I’m confident they will easily make it one more week. I could not get 4 weeks out of NiMh’s simply because the cut off voltage for these remotes is 1.3v.
The NiZn’s “seem” to be the Golden Ticket to power these remotes so far.
Of course, these are all unscientific opinions and observations so definitely take them with a grain of salt
I think using Batteroos with NiZn would not work….well maybe once. The reason being is that they work by boosting the voltage at the expense of current.
They will pull the NiZns (or any battery’s) internal voltage down so far that it will damage the NiZns permanently.
Doesn’t matter what voltage is showing outside the battery, what destroys the battery is the batteries actual voltage.
Someone needs to come up with an inexpensive (under $5.00) adjustable low voltage (1.00v - 5v) cut off board similar to the LN2596 Buck converter boards.
I hear you, Zebretta and that makes sense. And, relative to Hank’s comment, fragile flowers hold no charm nor utility for me. Even if I have an application that suits these cells’ particular needs, I’m not interested in giving them the coddling they require.
Cheers,
Wilkey
1). Were they ever used in a flashlight or any device drawing more than 500mA?
2). How did you charge them and to what voltage?
3). How did you protect them from overcharge?
4). How did you protect them from over discharge?
Seems I’ve either been lucky or careful. Out of 8 cells almost 10 years old I still have 6 functioning. The latest ‘death’ was using it in a photo strobe exactly like Ginseng. Worked great….while it worked. I’ll go back to Eneloops in that.
For now the remainder are in a cheap portable electric toothbrush and nose hair trimmer. The motors can take the voltage boost and work better, much better, and I can tell when they are getting weak and need charging simply by how they run.
Stock Power Genix, 2500mWh. I don’t have anything to do an amp capacity test on them. Come to think of it, I probably can use the NiXX discharge function on my hobby charger. I can set the cut-off voltage on it that way. Just never bothered.
Wilkey,
I’m not here to “sell” you or anyone on these cells….just to report my experience with them as clinically as possible.
I don’t find them any more fragile than the slew of RC lipos I have, some costing $150 each.
Like lipos, you have to be very careful how far you charge them and how far you discharge them.
Lipo charging requires care and oversight. RC hobbyists who use Lipos are used to “coddling” batteries :partying_face:
These are so much simpler to me….just set the charger to 1.8v and forget about em.
The device protects them on the discharge side so no complexity there either. I don’t personally see the “coddling” with NiZn’s that you do.
Apparently NiZn’s are not for you and there’s no problem with that. But don’t blame the battery. Like any “tool” you just have to know how and when to use them. Others may find applications like I have where they are perfect.
“Fragile Flowers”, on occasions, were just what was needed to get me something I wanted or to a place I wanted to be.
Cheers
> PowerGenix
I used the PowerGenix 4-cell charger that was bundled with eight PowerGenix AA cells in some sale a while ago.
That’s Model: F100011-14, which charges 4x cells at 1.6v, 750mA
“Charge only 1 to 4 …” at a time, it says on the back.
Just charged the 4 surviving cells I have left, overnight. Fresh off the charger they show: 1.22, 1.26, 1.35, and 1.5v
I’ll check them again in a day or three.
Drain? Used them various places I would otherwise have used Energizer lithium primaries for a little higher voltage.
Flashlights, AM/FM radios, and motion sensor lights, nothing super-bright, no estimate of the draw though.
> recollection of the peak charge ….?
Nope, Other than no surprise, so they at least met the claimed 1.6v
Hmmm, I wonder if over-discharge-protection circuits — like those added to li-ions — are available with trigger levels that would protect us from killing NiZn cells.
Just charged mine yesterday. 1.9v fresh off the stock charger. 1.85v 24 hours later. These are 2010 cells that have been mostly lightly used.
Currently running a discharge test on hobby charger, 0.10a down to 1.3v (per HJK test).
Addendum: After charging in stock PowerGenix charger I discharged 2 batteries using a hobby charger. Setting was 0.1A and 0.2a down to 1.3v. I think below 1.3v starts to damage them after looking at HJK’s discharge curves.
- 0.1A draw > 1020mA
- 0.2A draw > 720mA
I don’t know if the big difference was the draw or the aging difference in the batteries. These are old/used cells.
What’s the claimed output voltage of that charger? Model number?
(the one I have, PowerGenix NiZn charger model F100011-14, says 1.6v output)
(and has 0911 stamped into the plastic of the case below the label, presumably manufacturing month and date)
