Nice review thanks!! Curious, how stable is it without the center head strap? I frequently wear a HL loosely around my neck, so those center straps get in the way.
My thrunite TH20 also uses infinite ramping… its a GREAT ui for a headlamp.
That HC30 looks sweet.
The Imalent will probably not be bought for its looks (i.m.h.o.)…
Terrific and thorough review! Thanks for it!
From the pictures, it appears that the tint is on the cool side of neutral. I understand that we all have different tint perceptions.
What is your judgment of the comparative tint?
I like this light, have 2 of them and no problem so far. This light is good for its low price.
But I use battery chagers for battery so dont know how good internal charger is. And a decent barrery is included
Have other headlamp also( Nitecore H60, H50, 3 of Skilhunt H03, and alot of AA and aaa headlamp but this was really great for price/performance.
I’ve had this headlamp for about 6 months and it’s my go-to light for nearly any outdoor activity. Used the built-in charging once, just to affirm that it worked, which it did. I concur with all your review points, I don’t think there’s another headlamp near the coupon price which can lay a finger on it. Thanks for the review!
Thank you all for the kind words!
Its okay with out the top strap but id rather have it on for safety. It is a pain to get the top strap of its really made to used with it. As long as you tighten the straps enough it will work okay.
Lol its not really bad looking it just looks different. My HC30 has TIR optics. I think the HC30 looks a bit to plain. The H03 is a good in between. I do own 2 HC30s.
Yea it is still a cool tint but not way to bad in a sense. Doesn’t really answer your question lol. Its maybe around a 6000k tint. I have seen worse XPLHI tints. The S2+ in the pics is 4000-4500k tint and the H03 is a NW tint around 4500k also maybe? The NW tint in the H03 is different to the NW tint in my BLF X6 the H03 and S2+ are much warmer. If you want a more NW tint go for the H03 its about the same price with the discount but you lose the charger and battery plus the H03 uses optics so not much throw.
Your review made me order a HC30 actually.
Must say though, that stepless dimmer function and some more features of the Imalent are very nice, and the price is attractive too.
Yea the HC30 is a solid choice i would have a hard time choosing between these 3. They are both similiar but worlds apart. I think the Imalent and Skilhunt are a tad cheaper but the Nitecore should drop in price its about a year and half old almost. Heaps of option for optics for the Nitecore if you want to go that route.
I was waiting for a review on this one. Thanks. Do you have any measurements? Does it have any parasitic drain? What’s the real runtime?
Never mind, I see more reviews of this light. Thanks.
Thanks mate!
Yea the length and weight is in the review i will dig it out. I weighted the HR20 at 47 grams without the battery. Altogether with the included 18650 cell and headband i should add lol. It is 126 grams
Okay i found the calipers it is 10.6cm in overall length
Tail cap diameter is 2.3cm
Head diameter is 2.6cm at its biggest point
I can do run time test for you i am just sitting on the computer any ways. They say 1 hour and 45 min but that is with step down from 1000 lumens. I cant really measure when it step down.
The standby drain is super low 12.3 Microamps. I have never seen a reading this low lol.
I have this but with a black cover. Very flimsy connector microUSB. I’m afraid one day it will fall off along with the wire.
Another annoying me flicker on low mode. Not really weak but so.
Also, my not sealed. When unscrewing the cap and blowing inside the air easily exits through the opposite side.
My rating 3/5.
Does HR20 accept flat top batteries?
My rating 3/5.
Weird mine is fine. I even had in the rain when i was taking these pics as you can see no problem! I have no PWM either. Maybe its your battery connection?
I love infinite variable output, but dont think ill jump on this one. Ive read about the flicker in another thread.
Hey mate i just tried and it does! My LG HG2 are a tad short so it rattle a little nothing major. Only when you shake the light really hard.Same with my Samsung 25r they work but if you where to hit the light to hard it may turn of because the connection would be broken. I wouldn’t suggest hitting the light hard lol.
The head has a tint button on driver board that is maybe 1mm long.
No. The battery is not being.
Do not PWM. Trembling brightness. Approximately 10-20% brightness its happening.
This is a problem in the driver may not be correctly matched inductance or capacitance.
I just tried mine again but this time on a white wall through my camera and its completely fine. Maybe it was just the first ones? i would have noticed when i was taking pics. I will have a video up soonish i hope you will be able to see in that.
You mean its a frequency problem? I honestly can not see it.
I’m afraid to open it. I saw pictures of what’s inside and it does not inspire optimism me
There is a problem. What exactly is due, I do not know. If a newer version to fix it, it’s good.
