Or buy an original skilhunt one you cut off the upper part
If you do the headband through the front where the light is or attach both only to the side
it has a lot more grip on your head not moving while running
Because most of the silicone surface exposed to your forehead
Honestly cutting the upper part off and having the whole silicone stick to my forehead it feels more secure than with over the top and original position of the headband covering most of the silicone
I have an H51C I tried to put it in that band and it's a bit tight (needs to hands to rotate the light), but maybe it would loosen up? I guess I need to check the diameter of the battery tube when I get home. The fasttech one looks nice if it will fit.
Sorry for the silly question, but can someone show me a pic or a how to of how to actually assemble the headstrap, I just canāt seem to figure it outā¦ :person_facepalming:
I have one long strap and one short strap. I assume the short strap goes over the head, but it has a different clip on each end, and the one clip does not seem to be able to go through the other oneā¦. None of the bands have silicone or extra loops onā¦ā¦
Thanks
I tried this on but the rubber on the forehead crimpled vy the band so I changed the long one fitting. Now each end of the long band fitted to the rubber holders each side. No band go behind the rubber.
To H03 owners, has anybody ever replaced the TIR optic with a different one?
Currently looking at Ledil 16mm x 9.7mm TIR optics and wondering if they will be compatible/fit.
Was hoping to get a tighter beam without going to a reflector.
Not 100%, but pretty sure about the following: The maximum output decreases as your cells start to deplete. This means the full 1200 led lumens youāre only going to get with fairly full 4.2V cell. So if your voltage under load reduces, so does output. Therefore with 30Q you will have the same maximum output as with NCR18650B with full cell, but you will have a higher output for a longer period of time with 30Q than with NCR18650B.
