Yep, the UI is in the driver, but I at least prefer the sharp clicky feel of the Ti switch. Plus it of course enables tail standing.
Absolutely right :+1:
I do like that e-switch on the Tool Ti better. I’ll have to keep this mod in mind
Today I grind the top of the tailcap a little bit more and smoothing the edges. Feels more comfortable now when you use the switch and works better with a thick thumb :laughing:
This is what I used for the grind work with 80 and later 600 sandpaper.
Does it have a tiny button cell battery or am i mistaking?
Yes, the e-switch has a little battery or capacitor build in.
Much better :+1:
It is not a battery but a capacitor.
I use the copper switch on the Ti.
And again, today I grind the top of the tailcap a little bit more and smoothing the edges again. Now its perfect
And……perfect tailstand.
Well done! :+1:
Looks great!
I do wonder if the manufacturer themselves understand what a attractive option the copper version would be modified like this?
If it was sold like this I would have bought it already
Or a lamp with a conversion kit if there was one, not to fond of the original switch implementation on the non ti’s.
-lyse99
Woow, hi there… compliments and congrats :partying_face: !!
For exactly same purpose i ordered several myself
That brings me to ask: is there a thread about negativ ordering experiences somewhere?
Clearly your mod should be the standard :+1:
Thanks for sharing the process of your improvements
and for illustrative pics
Amazing :exclamation:
Sub’ed.
Will do this hack after I got another switch
But where does one get another switch?
Yes. Looks awesome!
I had a spare replacement Tool Ti tailcap laying around (my original tailcap WAS faulty until I took the circuit board out, cleaned the contacts with DeoxIT and screwed it back in).
After receiving my Tool Copper, I decided to have a crack at this mod. I’m quite pleased with the result:
“Ears” cut off with an angle grinder (although could have easily been done with a Dremel), and ground level with my Dremel. Dremel used to sand the end flush, and then worked up sandpaper grits from 120 grit to 1200 (could’ve gone higher but didn’t have anything higher left). Dremel with buffing wheel and polishing compound to buff, and a final polish with Autosol metal polish.
I used 400 grit to 1200 grit and then buffed to give the button a welcoming satin finish.
She’s now my prettiest copper light (her name’s May btw - is that weird?).
……can’t see the pics
Fixed, thanks
Your Lumintop Cu looks very good, is also very nice polished :+1:
I had already forgotten how good the Cu looks polished without patina, great job!
Here is mine with the Massdrop brass:
