I Haven’t seen any mention of this light here yet; I was just poking around on Gearbest, noticed that they have a page up for their new zanflare F2.
200 Lumen XP-G3 2xAA with battery level indicator. Appears to have a cool and neutral white option.
Output level seems a bit low and the strobe does not appear to be hidden, but I suppose it could use the long press like the Bistro firmware to activate.
I see what you mean, the die does not look like an XP-G3. However, I know that Gearbest tried to get everything right with their first light , I doubt they would throw that all away by lying about their emitter. I would assume that the light is not yet in production, and the pictured is a prototype. I don’t see that being a LB LED.
Finally. I was looking for cheap 2 x AA flashlight for my car and general use at home and it fits perfect.
Smooth reflector, 2,8 cm head, XP-G3 diode makes 200 meters beam distance. This is how it should be done.
Let’s see first review.
Any info about discount?
when they write X in an IP indication means that the X value is not specified.
So IP68 means mechanical resistance 6, water resistance 8
IPX8 means mechanical resistance not specified, water resistance 8
Is it a mistake, or is the runtime at hi (200 lm) level only .63 hours?? If it dims down to medium and continues running for some time then maybe that might be acceptable. But if it just goes off or very dim after only 36 mins on hi with 2xAA, then that seems really short. Seems like a terribly inefficient driver.
