How do they compare to this LED?
http://www.gearbest.com/led-flashlights/pp_277704.html
for now $20 one gets a nice flashlight with it.
Some specs would be nice.
Wavelength, Vf and maximum current.
I don’t know how they compare as I don’t have that light. The linked Convoy S2+ is apparently using a NCSU276A (I might be wrong) but that led costs less than half of what 033b are still selling for.
Could there be a spectral difference after all? I was told that the Nichias in those golden-ceramic packages with glass lens (i can’t find what the package is called) are made for prolonged life under industrial use.
Maybe some UV-savvy flashaholic fella could enlighten us.
I’m waiting for several hosts to arrive so I can test them outdoors.
There’s also the Nichia UV Jaxman with the filter for $47
They look big.
Is it 5050 size?
Sorry, forgot to list them. I’ll update the listing
NCSU033B(T) P9
Vf=3.6-4.0V
If=700mA
If(pulsed)=1000mA
Ir=85mA
PD=3.08W
Tj=130
λp=365
λd=9nm
Flux=350-390mW
The package is big, the die I think is 1x1mm
They should fit on XHP70 or MK-R boards
- NCSU033B datasheet (the emitter being sold here)
- NCSU276A datasheet (the emitter used in the Nichia UV Convoy, in 365nm)
I’m not seeing P9 listed as a flux bin for the 033B. The highest flux bin listed is P34d22, which is 590-640mW at 500mA forward current. The lowest flux bin in the 276A is P35d21, which is 640-700mW at 500mA.
I know fairly little about UV LEDs, so I could easily be missing something obvious, but I don’t see an advantage to the 033B over the 276A.
There seems to be multiple different editions of the NCSU033B(T) which I cant find a documentation for.
Googling after NCSU033B P9 350 ends up with few links to a datasheet with earlier binning nomenclature.
As for the objective differences between the NCSU033B and NCSU276A these are what I could find is:
- NCSU033B has a slighly narrower beam profile 115° vs 130°
- NCSU033B has a better thermal resistance 4.4°C/W vs 11°C/W
- on the other hand NCSU276A has more raw output
I think these models are not a replacement to each other but rather a compliment.
It’s true that, there could be many applications where the 033B (or it’s bigger brothers sharing the same package size such as: NVSU333A, NC4U133B) would NOT fit the bill due to larger size and higher cost.
Nonetheless, consindering the constructive feedback I’ve received, I’ve readjusted the price.
Thanks for offering these!
I’ll take one. Sent you a pm.
There is one very big difference between these and the newer Nichias:
These older ones have a central solder pad for heatsinking. This is important because UV LEDs are much more heat sensitive than white LEDs. They start to die at much lower temperatures.
The newer ones in turn are much more efficient and thus brighter (but only when they are kept cool).
Please check out this thread here (it’s in German). It shows what happens to the Nichia 276 when it gets too hot inside a Convoy S2+. My light also now has this problem :(.
Sorry to hear about your problem.
Thanks for the link. You have a good point there: in addition to a better thermal resistance, the older package can obviously endure a noticeably higher junction temperature
table(table#posts).
|NCSU033B|NCSU0276A|
|Tj=130°C|Tj=90°C|
I will take one also.
Nice thanks all for this educational thread
Scouring a high drain cell for NY S2+ Nichia now, if it fails I want one too!
I trully hope your S2+ UV Nichia does *NOT *fail. But I will reserve one NCSU033B for you in any case
in the 40$ new price range you got a 233A
Tj is also 130°C
http://www.nichia.co.jp/specification/products/led/NVSU233A-E.pdf
lowest flux bin 800-870mW
for the 233 and 276A I can only recommend to get djozz custom board
or if you are sick to get 5W 365nm get the 333A
http://www.nichia.co.jp/specification/products/led/NVSU333A-E.pdf
lowest flux bin 3160mW
has the same 7x7mm footprint with thermal pad
I’ll try to get one for the fun of it
Received some copper and alu. boards for testing how these UV leds fit…
The universal base boards made for both XHP70 & MK-R seem to be a better match than the ones suitable for XHP50 & XHP70. Both are perfectly usable, nonetheless :+1:
I think there will be a short circuit. The center pad is too wide on the star
I thought so too, but considering that the solder bulges slightly up it worked without a problem. The led got pulled into it’s place once the solder started to flow.
I’ve had (the start) running yesterday without any issues. Then I decided to test the limits…
Hi again, your LED should be on it’s way to Germany as we speak.
I’ve run a test to see if these leds have the same issue…
After pushing the test-unit (the one on the DTP star) to 1.7A i had to stop the test, as I did not have proper isolation of the rest of the lab from UV bombardment.
The die seems unaffected. The star temperature reached around 56°C
