One pill I built with an AK 101-A1 driver (L-M-H mode order), a filed down bergquist star & oram oslon SFH4715AS IR led.
I first blew a SFH4725S led, but fortunately I ordered the 860nm variant as well. It’s for some to-be-built nightvision hunting gear.
Second pill I built with unmodded BLF A6 driver(Bistro), filed down Noctigon MCPCB & XPL V6 0D Led.
Thereafter I dedomed the led with a knife and built the second pill. I got a bit messy, but it works more than well in the end! Bypassed both springs and it pulls 5,2Amp. It has quite a nice white/yellowy tint to it after the dedome.
I tried to measure lux with my phone, but it went straight to >211Klux @100cm, wich is the max the sensor can measure… There’s a first time for everything
Crazy thrower, can’t wait to use it in the field. I can just pop in another pill for the task needed and only carry one light with me.
Test pic
Building 400mtr away over city light.
Best thrower I own to date!
I’ve been wanting to do this since before I decided to actually get one and the other day I finally disassembled one and cut the lobes off with a hack saw. Then I chuckle it into my drill press/wannabe lathe. I continued further but stopped before getting to the bottom of the slots as that would reach the internal o-ring groves(very bad). I have a piece of Teak that might go well with a few fins. I’ll see which metal looks best to me.
Dedomed the LED in gas and sealed it with clear laquer
The Nanjg 105C driver was hanging in the pill between a contact board and LED
Changed the driver to Biscotti and removed the contact board and soldered the driver to the ring that is pressed in pill again
Spring bypass on driver and tailcap
The star is DTP copper but a bit thin, mounted with Arctic Silver 5 again
LED centering ring and gasket painted black
Pill painted black mounted with thermal paste to the tube
Lexel, did you remove the LED to confirm the MCPCB is DTP, or is there some other way to confirm it? You can have copper MCPCB without DTP.
I thought the way to test for DTP (instead of just a copper MCPCB with no DTP) was to test for electrical continuity from the bottom of the MCPCB to the LED heat pad.
Is it possible to confirm if an MCPCB is DTP with the LED still attached to it?
DTP confirmation, if there’s excess solder squeezed out from the center pad then check continuity to the bottom from there. It’s trueness that not all copper boards are DTP.
Zommies should be as light as possible in their lenses caliber and unnecessary hunch design does not help with heat sinking anyway so this is the way to go…
Very good my friend, I have a restlessness, I paint the pill black and centering to eliminate the annoying rings of light? Eliminates them completely? Thank you
I hope you’ll still like it when finished as some of the weight will be added back but with a significant increase in surface area(at least where the pill is located). To be honest though, it’s mostly cosmetic since any gain made by the copper could well be offset by the addition of the aluminum to copper thermal break. I could do wood only but fins just look neat.
Lexel, what paint do you use? Is the paint the same type on the emitter, gasket, and centering ring? It looks much glossier on the emitter is the reason I ask.
I wonder if chalkboard paint would work well?
In other news, for those of us in the USA, I found a good material for doing flood modification, without losing spot capability: 3/4” Type M copper pipe.
The nominal ID of this pipe is 20.60mm, and the OD of the threads on the B158 pill are 20.72 (as measured by me). So you need to sand the ID of the pipe very little - I use sandpaper wrapped around a deep socket from my toolbox and it only takes a couple minutes.
The OD of the copper pipe is less than the ID of the B158 body, so the light can still zoom in to spot setting all the way without issues.
So basically you make a ring of copper about 5mm wide, and slip it onto the pill. I like 5mm because it still gives plenty of thread engagement between the pill and flashlight body.
You will need to add some length to the tailcap end to compensate for the 5mm that you just moved the pill. I solder 5mmx2mm brass bottons to the top of the spring cap:
Now you can get more flood in the widest setting, there is little downside because the light can still zoom out completely normally (no downside other than extra work involved).
I can take some pictures next week to better illustrate how it all goes together.
