I have seen people use a 36k for a 3s setup and 48k for 4s IIRC. Although they still needed fine tuning in the firmware IIRC. Still it shows you need to increase R1.
This test was done on the J4 looking pretty spectacular. Cree list a K4 that does 350 more lumen at 3 amps than the J4. So 5000 lumens is very doable, just not as pretty as this J4 A3 5000K LED. Now just sit back and wait for the Cree XHP70.2 cause the Heart of Texas is going to have scorch marks all over the place.
You would need a fixed voltage drop of 3.0 Volts over the 220 Ohm resistor, so that when the Voltage goes down to 6 Volts the driver will get 3.0 Volts and low voltage warning will happen.
So i think you can replace the 220 Ohm resistor with a 3.0 Volts zener (in ‘anti-series’) and forget about the parallel zener (from the zener mod).
But, that means the MCU gets maximum 5.3 Volts minus the 0.6 Vf of the protection diode = 4.7 Volts maximum.
I don’t know how much Voltage the MCU can take though, and i haven’t tried this idea either…
Yes, but that’s when you use the zener in prallel, and that’s to be expected.
What i’m proposing is putting a 3.0 Volts zener in series (but the ‘wrong way around’) in stead of the 220 Ohm resistor so you use its reverse voltage drop.
It will then just eat 3.0 Volts of 6.0 to 8.4 Volts, so that when battery drops below 6 Volts, the MCU will think it’s 3.0 Volts and starts blinking in low mode.
This is getting a bit off topic i guess…
But my idea is to avoid SMD soldering as much as possible, so i’m thinking about using a fixed 3 volts voltage drop in stead of a 220 Ohm resistor and the parallel Zener.
You can obtain 3 Volts drop with 5x Si diode in series, but that’s a but bulky…
So i though about using a 3.0 Volts Zener in series, that is, if they even exist… :person_facepalming:
Basically what I figured, the xhp50.2 should give the xhp70 a run for it’s money without a donut hole. Not a bad LED option for sure if we can find some drivers capable of driving it properly.
I have a couple stock SD75’s with OP and SMO reflectors, FETDD drivers, LD2-3 at 12 amps that I would like to try this in, but is 5000k the highest tint/kelvin/temp out? If possible a link to it would be greatly appreciated.
Alternatively, could there be a special FET MCPCB that would mount to the driver side of the LED shelf? Starting from the front of the light, there’d be a sandwich like this:
LED
LED MCPCB
LED Shelf / Pill
FET MCPCB
FET
Airspace
Driver
with a couple of small bolts keeping the FET MCPCB in place, and suitable amounts of thermal compound.
This assumes enough space in the driver cavity, of course, but it might help to avoid space problems on the LED side, given that reflectors / optics tend to sit quite close to the surface of the LED MCPCB, and the LED itself sits so inconveniently in the middle
It also allows the use of any stock LED MCPCB and keeps the FET gate wire wholly inside the driver cavity, if that makes a difference.
Jerommel has given the graph an incorrect fuzzy title (although he did refer to the origin of the graph where the correct information can be found). The title says that the the XHP70 test was ‘in less than ideal circumstances’ while in fact in the graph two XHP70 tests are to be seen, of which the purple one is wrong and must be ignored (the led was reflowed on a bad performing makeshift board), the red graph is correct, on a quality copper DTP board, under as perfect circumstances as I can create them.
I always make a point of giving my graphs headers that describe the contents as complete as possible so that they can be copy-pasted without loosing their context, but Jerommel (unintendedly), by writing a new header, has removed that context here.
I have an Acebeam K60, if I install this led and according to the graph I would lose around 600 lumens but gain more throw? Doesn’t sound like a bad trade. :heart_eyes:
It’s a disclaimer actually, because it’s not made by you this way, not based on your measurements but by image manipulation done by me.
of course.
You wrote the red line represents an abused LED (resulting in higher Vf and lower output, but on a proper MCPCB) so i wouldn’t call that ideal circumstances either.
I love the charting, the information it imparts, the graph showing all the pertinent aspects give a great idea of what to expect…
However, I have an XHP-70 in a Convoy L6 making 7245 lumens at 11.97A, far above the plot and respectably higher than the XHP-50.2 shows. Not sure then how to interpret the graph.
While I do have 4 of these 5000K 50.2’s on the way, the main plan is to build 3 of them into a triple. I don’t know quite yet what I’ll do with the 4th, perhaps put it in another L6 and build the same ramping driver as the other for a direct comparison?
The problem with this is that it would not work with all hosts, only those that have a thick enough shelf to allow a screw to be used to mount the bottom side mcpcb among other issues. If you were desinging a light from scratch there are lots of ways to power the xhp50.2 but in a retrofit setup we are much more limited and need a more universal option.
A good preforming buck driver is the best idea but the best we have at this point is the mtnmax with ~5A.
