Pulled mine apart and it looks like its fine with no spacers. Will look at it closer tomorrow. Beam profile looks pretty good too.
edit… no spacers in mine. But there is no o-ring sealing the lens, and the lens just sits on top of the reflector, so there is no way this could be IPX-8 water proof or water resistant.
I pushed the bezel against the corner of a peice of pine (a soft wood) and turned. After removing the bezel, I then used a pick to gently pry out the first O-Ring. Then I used the pick to gently pry up the reflector.
Texas_Ace,
The led shelf does appear to be thin. It isn't flat on the back side (by design to clear the inductor). The thickest part is about .05", the thinnest part about .04" (about 1mm). All three of my VG10's had the short reflector and stack of stuff under the base.
Don't worry. Thorfire will make you whole. They got right back to me with a generous solution. I told them I would be happy with just a 50% refund because I can make an alternative use for my lights.
EDIT: Just PM the OP about your situation and he will get back to you soon.
I see my reply cross posted. So I will move it here with a quote. You're very welcome. Thank you for the feedback.
Your are correct on that. When I across these, I file them the lip down to just shy of reaching up into the plane of the reflective surface. Improves the beam pattern nicely.
While this is unacceptable for a light, particularly one sold to BLF, before anyone goes off on thorfire too hard, keep in mind that mistakes happen.
The issue at this point is not the mistake itself but how thorfire deals with it and how they go about preventing this from happening in the future.
The best lessons come from mistakes that you can learn from, assuming of course that they make it right to all those that got the bad lights.
I would encourage everyone to contact thorfire as they requested and BE REASONABLE in coming to a solution. Keep in mind that no matter what the solution is, thorfire is going to loose a lot of money on this.
We want to encourage companies like thorfire to work with us, not against us. This means we need to build a good working relationship with them like with have with convoy and others.
Lights like the Q8 would not happen without companies like thorfire, so we need them as well.
Well said! This is so important! as a small business, we always emphasized that when mistakes happen, and they always will, what is important is not pointing the finger of blame but correctly identifying the problem, correcting it, and moving forward ensure that it does not happen again.
Very good points and well stated. ThorFire is handling this hiccup with class. It's when things go wrong that you see the true character of a person/company and how strong the relationship actually is. I'm chalking this up to one of those unfortunate situations that happen and I feel more confident in ThorFire than I already felt.
Well said, I have more than 10 of Thorfire VG10 (including 4 on the way) for whole my family, will need a lot of time to collect them back and check all of them this weekend. The 1st one in my work space is OK. :person_facepalming:
I don’t think the average smoe on Amazon would ever notice it. Half of them don’t even know you have to recharge an 18650. “My light is blinking, I’m returning it” or they can’t find the batteries at Walmart, etc…
I’m not looking for refunds (as I absolutely don’t want to return the lights!), but asked if they’d have something like a copper disk to fit between shelf and LED, or the right-sized reflector to just swap in. I’d rather keep the lights and just fix them, rather than send them back.
Figure something like that (a fix), made in bulk and dropped in the mail, would be cheaper in the long run than refunding people the purchase prices. I’d be happy with that, but can’t speak for anyone else.
Anyway, I’ll see what’s on the table when I get a reply. And will add that’s a nice move on TF’s part to just own up and offer to make things right.
