Have you tried bypassing the tailcaps all together to see how the lights work? Using a thick paper clip or something to connect the bottom of the battery tube to the negative of the cell.
I really having rarely have used the stock VG10 switches. The lights are much nicer with reverse-clickie switches. So I pretty much swap them before even using the light. Throw in a PD68 lighted tailcap board while at it. You need not bleeder resistor with the stock driver.
I just got back a reply through Amazon, basically āCan you describe the problem in detail?ā, as if no one knows whatās going on.
I did specifically mention the thread on BLF, so that in case someone there knows the problem, I could short-circuit the multiple backānāforth to find someone who knows about it. Guess notā¦
Why do I get the feeling this is going to end badly?
When the problems became clear, we the Q-team were a bit worried and following this
Besides TF stepping up to correct things I think Barry/Thorfire understands the importance of a well executed Q8.
Personally when I read (long ago) what āmarketing talkā Thorfire wrote for the then V2 of the VG10 I wanted one, they said something like āthe tactical ring sucked so we adapted itā and this was so āun-marketingā I really liked it.
Got a VG10 from BLFer X3 and liked it a lot, it started to good relationship with Barry (I wrote a little review as response to a Dutch blog and Barry shipped the S70 and S50 to me for review, starting the whole review thing for me and making them a good candidate for the Q8.
My guess is that the people that manage amazon and those that post on here are different people and work through different channels. So the right hand not talking to the left hand is my first guess in this case.
Yah, I figured that, but in an early message I got
As amazon order must be handled on amazon backstage, Our customer service will contact you and take care of it.
so I figured someone on the BLF side had to get in touch with someone on the Amazon side to make anything happen.
Unno, hopefully itāll all shake out.
Soā¦ what are we talking about, anyway? I was assured that I wouldnāt have to return the lights, but whatās on the table? I heard ārefund or replacement, as you likeā, but does that mean a 1:1 set of replacement lights?? Or 100% refund?!? Man, theyād take a bath on that if thatās the case.
I ran the ā10 on high for a few min, and it didnāt get as āwarmā as I expected, so Iām suspecting the thermal path isnāt as good as it could be. That concerns me a bit, so yeah, I definitely want to fix the lights. But wow, if thatās the offer, and if that goes through, then TF is pretty stand-up.
The holsters for the VG10? I thought they were rather big for the ā10, even in a head-down config, but either way (HU or HD) you can slide the ā10 to the side and remove it from the holster w/o undoing the velcroed flap.
But!, the holster perfectly fits my DV-S9, albeit a bit snugly. And thatās a 26650 light!
Iām using a generic Jetbeam holster (from FT, āthough now discontinued) for my ā10, albeit in a head-up config. Same size as for a ā501, ā502, other similar-sized 18650 lights. Just need to give it a little twist to tuck the fins into the holster and get the tail to seat fully in the holster as far down as itāll go.
Anyhoo, if anyone else thinks the supplied holster is a tad big for the ā10, you can use the holster for a bigger light, and a smaller holster for the ā10. Works out perfectly!
Thorfire offered full refund right away so respect for them. I only agreed on half of price as it seems fair to me. Half is enough to pay for copper spacer to make it perfect.
Didnāt someone say that the convoy M2 reflector fit perfectly in this light without the need for spacers?
If so maybe those reflectors could be sourced, either from simon or another option, and used to fix these lights. That would seem to be the best option for this. Followed by a copper spacer.
I mentioned it in my quad build using the copper quad spacer for the M2ā¦ theoretically possible but I havenāt checked yet. Got to the bench and tangents startedā¦ Finished 2 other lights but quickly forgot what I initially wanted to do. Will try again.
I also received an email from āthorfire officialā about my lights. I have replied and have not heard back in a few days. Time to go directly through Amazon.
Well the M2 erflector does physically fit into these VG10 with the spacers under emitter, using reflector without spacers.
I did have to file/sand top of reflector to get it to seat the bezel to body. After test fitting I chose to build one up using a XM-L2 U4 1A on a 20mm Noctigon and More filing/sanding off the top was needed because of the thicker MCPCB and reflector spacer used. M2 uses an OP reflector. Finished light off with an A6 Fet driver and bypassed the tail SW spring.
Used the original VG10 parts for the Lens
and T-Pad quad with XP-L HI reflowed by MtnE.
If you meant Optic it is the Carclo 10622 24mm quad Narrow Spot Plain TIR from Kirill.
