I insist:
Click on images to enlarge.
Thanks for the pictures. Maybe the tailcap is glued and screwed in. Somehow the disc springs have to come into this position during production.
Did someone who has this light tried to unscrew the tailcap with a little more force?!
Wow, what a mess. It’s hard to tell, but they must be soldered in place. They don’t look very strong, but I guess they are more durable than coil springs.
To keep using the stock batteries, it looks like you would need to number the battery holes and then use a metal tool (like dental scraper) to pull up on the 2 ears that touch the battery until they are all the same height. Then after using the light, check the battery voltage and battery heights to see if the ears are staying in place or bending down too far.
As long as all 4 discharge at the same rate, then your good, but if one battery has higher voltage, then it might not be getting good contact. Keep notes because it may be the same disc spring getting flat and not springing back up.
If you have a heat gun you can heat the rear tail cap around the threads then turn it with a rubber strap wrench. That might get it loose.
If the tail cap can be unscrewed then you could solder in a set of double springs or one set with wire bypasses. You may be forced to buy new, shorter batteries though.
Has anyone told Imalent that the little spring ears are bending down and not springing back up and it’s causing uneven battery drain? I’d be curious to hear what they say.
It’s also possible that due to the higher spring pressure of the disc springs and the design in general, that you need to tighten the battery tube tighter than the average light to get all 4 batteries making good contact.
Do the instructions say how tight to turn the battery tube?
My question is why does Imalent have more problems with their products than most other flashlight companies? My experience with them hasn’t been good.
Very little testing and puzzling what works and what doesn’t? Produce as fast as possible to reduce cost?
Edit:
Some time ago there were rumors about a 16000 lumen Noctigon powered by 8x18650 cells. Hank Wang said that hopefully it will see daylight before Christmas 2016. A couple of months ago he mentioned that the design was more difficult than anticipated, so there is going to be a delay. I haven’t read anything about it since then… Basically a good design needs time, and time is money.
I think they try to be fancy to stand out from the crowd and somehow get the basics wrong.
They have design flaws all over. The 4 new lights are said to have very hard to find buttons in the dark, the drivers are flaky and the DT series have these disc springs. Maybe they rush things to market. Maybe they test a little and know the faults, but think it costs too much to fix it, so just sell it like it is.
Some of this could be forgiven if the company took care of their customers, but they dont. They try to ignore them. That’s the worst part.
I wanted a DN70 real bad, but it’s a crap shoot if I’ll get a good one or a bad one. If the good one goes out later, I’m still screwed. I just don’t buy from Imalent. Luckily there are lots of flashlight companies.
I was considering a DT70, but looks like I should wait for the bigger brand names.
How about Acebeam X45?
I personally haven’t had one of their lights yet; thought about the K70 a while back but saw some reports/videos of smoke building up inside the head.
Imalent- young company, good products, rushing on the marker: voila, there we go, many minor( sometimes major) mistakes.
Exacly like Manker - its only Manker products arent even inovative, yet Imalent`s are
Really makes me want to Frankenstein a bunch of companies into one…
Got screwed once with Imalent. Never again. Never owned a Manker.
One of my DN35'S had the same issue. Even though it is a 26650 cell, the spring needed just maybe to be 1mm taller.
I took my spring out. Set of needle nose pliers and it popped right out. It was held in place by nothing but it's own diameter. No glue or solder. Really hard to press back in but I got it done
What worked on just that light was screwing the head on as tight as I possibly could by hand. No problems after that.
Not sure that will help here. DN35'S and 70's oy have a single 26650 cell. You have 4 18650's so it could make the other 3 fit too tight.
I sent all of my video and information to Imalent. I was thanked, and told they would look into it.
Wish I could help more.
imalent, what junk…
hear nothing but bad reports on these
and NO customer support
they should be sued and shut down
I have two sitting about 3 feet from me the DN70 and 35 ad both are working perfectly. It is a newer company so that could all change at any moment, but I have had the 35 for a couple of months now and the 70 for about a month no problems.
I have had 2 Streamlight Stingers in the last 6 months and both died when they were dropped about 3 feet for the first one during a hunt, and the other was dropped while it was still in the shipping carton so no way to say for sure if it was D.O.A. or when it was dropped here.
Then on the flip side of those I have an old original Ultrafire sk68 that has been beat, dropped, kicked, stepped on and 2 years later it still works every time I reach for it.
I am not outright defending Imalent. I am saying that when I contacted them directly it did take a few days to get a reply but I had no problem with their support.
Any light can have an issue and almost all rate their lumen count far above anything realistic.
I wish they would offer to send replacement parts to customers that have warranty issues and the knowledge to fix it themselves. Currently they want people to ship their light back to China at roughly $50 one way with no insurance.
I was thinking about rolling the dice on a DN70 and hoping I got a good one, but I’m not really a gambler.
I did tell them up front that me shipping anything to China was out of the question. I asked if they had any dealer in the states at all that I could maybe order parts or even ship it to them if I had to.
Got it worked out before any of it came to that.
Honestly though it kind of surprised me when they agreed to start including a spare USB cover. I figured well that is a start.
If the light is bad when it arrives the issue should be resolved with the retailer, not the manufacturer. One must check the retailer policy to see if the return cost is up to them or to the buyer.
It seems that what’s specific to Imalent is that they don’t sell parts. Warranty is always a risk when buying from abroad, be it from China or the US. Even if the manufacturer does the repair without cost, the return and send back often have to be paid by the client. We’re quite used to this in Brazil…
I got a dt70 and my battery holder has 4 large springs. I also have the older version that has the weird looking things that act as spring.
Although they fixes this issue, the springs are very stiff and makes screwing the head quite tight. The older ‘spring’ made a much smoother screw motion of the head into the battery compartment.
