Production can be finished next weekend. MD requested a sample before setting up the GB. This could take about another 5 days.
That’s the best I’m expecting.
@T18 PM sent about the driver. and YES, I’m wanting to make a upgraded version of Triple Ti I and Ti II (X6)
Back then I was not so experienced with the production. I really want to correct the mistakes, and make some better lights.
@Meich Yes, it is awesome. I’m also thinking to remove the hole for strip. Someone complained that it pokes the palm a little.
Maybe make a clip with 2 screws, which makes it higher class IMO.
@lumenzilla RCR123/16340 and even 18650, it will be on the waiting list.
Gimme the Ti-lan please. This one is perfect with the upgraded reflector. Just give an option without any hidden carnival modes ;). Mine. Moonlight-low-med-high-(turbo). comes on in low or med. PWM doesn’t matter as long as the frequency is high enough for the PWM-Taliban not able to detect it without camera settings etc ;). CRI doesn’t matter much on this kins of light as long as it isn’t obviously reddish (mistaken by some for “high CRI”, the CRI Taliban). Just 5000-5500 proper “natural white” LED please.
It’s true. Olight’s 14500 is about 1-2 mm longer than my Eneloop.
Btw here’s my investigation:
Spring Swap
Pineapple’s back spring is a bit thick and long. So I suspected that this may caused the problem. It even made my Olight battery a bit dented inside (see picture).
So I swapped the spring with another one taken from dead driver. It’s shorter and slimmer, I think it’s better than original one because it has golden color :laughing:
It works BUT only when the tail is not fully tightened.
FAILED.
More insulation
I thought that the problem was short circuit with the retainer ring at its tailcap. So I added nail paint into the retainer ring as well as around the negative pole of the battery to avoid short contact.
The result is still the same as above. Only working when the head or tailcap is a bit loosen.
FAILED
Magical Stuff
Just when I didn’t know what to do, I tried to loosen the retainer ring for driver a bit. Just in case it will work.
Some times I’ve had to cut the wrap from the neg end of the cell back even with edge of the cell to make contact on some lights and some cells,
I’m using the WindyFire 14500 cells with this pineapp and they are perfect in flat and button, that cell looks sort of scuffed up on the wrap so, just a thought.
