[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
Not sure that these will help alot, but all were shot at 4500k and all leds except the 7A are within 1000k of 4500k. It was cold and windy outside and my daughter and I got cold. We have better nights this week and I may redo this work with the camera on auto.
XM-L2 4C
XP-L Hi 5A2
XM-L2 5C1
XM-L2 7A2
219C SW403
219B-V1 SW45k
Well that was quick, thanks!
Sorry the pics kinda suck, it was really cold and windy!
Received my order today. Thank you very much.
I just used up the last of my 219B’s. I built a quad VG-10 with them and it is amazing. Around ~2100 lumens but a truly amazing tint. Nice and floody as well (although less floody then I expected) and perfect for a photo light. Already used it to great success for some extra lighting for some pictures.
In a quad setup with a TA driver and 20AWG wires it only pulls around ~10A on a HE2 battery, I expected more but glad at the results due to the heat of almost 40W being a bit more then the VG-10 can handle.
Now to wait for some more of these. I was doing some experiments last night with my EDC options. All LED’s have the dome on.
A single 219C 4000k will do ~775 lumens and 143m of throw at 2.5A and ~1100 lumens with 182m of throw on turbo with 6A.
A triple 219C 4000k will do ~875 lumens and ~92m of throw (84m of throw with a 15011 optic but more flood) at 2.5A. Going to 2100 lumens and 140m of throw (133m with 15011 optic) on turbo at ~16A (didn’t measure it but I think it was around here).
A triple 219B 9080 does ~800 lumens and ~96m of throw at 2.5A going to ~1750 lumens and 144m of throw on turbo at ~10A.
Based on these results I am not seeing any reason to not use the 219B triple as my EDC as it gives me the best of both throw and lumens. Now to decide if it is worth ripping apart 2 lights to build a EDC triple 219B now or wait for the next batch to become available and build a new light then……
The gain decrease in lumen from 2,5A to 10A and to 16A is amazingly steep. I imagine the heat they create must be more than 60C at the body
Is anybody know where to buy mcpcb for 144 16/14mm, 1.6mm , noDTP?
I like 144 in H03 host, but without proper mcpcb xhp50 is more convenient to install…
Here are some: Testing a custom made 16mm Nichia 119 copper core board (non-DTP), edit:sold out
But you need to scratch the pads a little bigger.
He used it in his test: Nichia 144A series, an output test of a 6500K 70 CRI sample. Nov 7th: added a test of a 5700K R9050 version of the 144A
And make spacer 0.6mm, and applay 2 layers of thermal paste. So it not for 144 and not 1.6mm.
Place the spacer for optics on top of it rather than using two layers of thermal paste or solder.
That is a great idea, scratch the solder mask off the entire two traces of the board and solder two 0.6mm copper plates on top covering (most of) them (triangles will do the job). It will give you an almost (or entire) DTP performance. It will be a pain to solder the wires then, so make sure that you already apply solder blobs on the wire-pads during reflow!
Don’t forget to apply pressure while soldering those two copper plates. Thicker is better (if no optics involved). If you use aluminum reflector you can connect one of them to the reflector to get double sided cooling (isolate the other one)
djozz, clemence thank you for your ideas! I will try to find suitable spacer, of course. But now xhp50 with native H03 copper mcmcb is more cheap and convenient. Although a bit worse in CRI and r9
Oh, they get WAY more then 60C. I desoldered the wires from the mcpcb when doing a turbo test on my first triple in less then 90 seconds.
Now days I use thin wires to reduce the current and I use S2 instead of the S2+ since it has a thicker spacer.
With 10A and the S2 or S8 host with a copper spacer I can generally get around 60 seconds before it gets too hot and starts thermal regulation.
I tested a few other tube lights today for more comparisons to the earlier numbers:
Triple XP-G3 mixed tint 85CRI did 1150 lumens @ 2.5A with 100m of throw, Turbo was 2900 lumens with 170m of throw all with the 15011 optic in order to get rid of the tint shift issues. With a high drain cell and 14A on turbo lumens jumped to 3400 and a bit more throw.
I have a single XP-L HI with an S6 reflector that makes got 220M of throw at 2.5A and 260m of throw on turbo at ~6A. The best EDC thrower I have.
The best overall setup if you are not worried about CRI is the triple XP-L HI with ~175m of throw on turbo (driver didn’t have the regulated low mode) and ~3000 lumens @ 11A. Sadly the CRI sucks on it.
I am swapping EDC lights out daily right now to see which light works the best for me.
The ultimate setup would be an XHP50.2 or the 144A with a thermal pad and wired for 3V operation with no dome. I would totally rock that setup even if it costs $15 or $20 for the LED as long as it didn’t have tint shift issues and 90+ CRI.
You’ll have it soon then :wink:
Did I miss something or do you have something to share?
You miss something and I have something :slight_smile:
lol, mind making it easy for me, got a link to the said thing? I have been super busy recently and have not ready the last many pages of this thread nor any other thread posted on here recently.
You can PM me if you want, you have my attention that is for sure.
… ? ? ! ? :slight_smile:
LATEST INVENTORY STOCK [170325, 09:15 GMT +8]
LED Type CCT Available/STOCK*1
1 NVSL219B-V1 SW45K [4500K ANSI BBL] SOLD OUT
2 NVSL219CT SM273 [2700K 3 steps MacAdams] 119
3 NVSL219CT SM303 [3000K 3 steps MacAdams] 150
4 NVSL219CT SM353 [3500K 3 steps MacAdams] 103
5 NVSL219CT SM403 [4000K 3 steps MacAdams] SOLD OUT
6 NVSW219CT SM503 [5000K 3 steps MacAdams] SOLD OUT
7 NVWL219CT SM573 [5700K 3 steps MacAdams] 147
8 NVSW319ATE SM655 [6500K 5 steps MacAdams] 73
9 NVSL319ATE SM305 [3000K 5 steps MacAdams] 65
10 NVSL319ATE SM505 [5000K 5 steps MacAdams] 6
11 NV4L144AM SM453 [4500K 3 steps MacAdams] 64
12 NV4W144AM SM503 [5000K 3 steps MacAdams] 81
13 NV4W144AM SM573 [5700K 3 steps MacAdams] 85
14 VirEnce S3030 CDTP board 20
